HP Stream 14-CB174WM Lower Case Replacement
    1. HP Stream 14-CB174WM Lower Case Replacement, Lower Case: step 1, image 1 of 2 HP Stream 14-CB174WM Lower Case Replacement, Lower Case: step 1, image 2 of 2
      • Use an opening pick to gently pry up the edge of the rubber foot.
      • Grab the lifted edge of the foot and gently pull it away.
      • Repeat for the other rubber foot.
      • The oils on your skin can damage the adhesive on the rubber feet. Try not to touch the adhesive part of the feet with your hands.
      Ask FixBot
    2. HP Stream 14-CB174WM Lower Case Replacement: step 2, image 1 of 2 HP Stream 14-CB174WM Lower Case Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the eight 6.6 mm screws that secure the lower case.
      Ask FixBot
    3. HP Stream 14-CB174WM Lower Case Replacement: step 3, image 1 of 3 HP Stream 14-CB174WM Lower Case Replacement: step 3, image 2 of 3 HP Stream 14-CB174WM Lower Case Replacement: step 3, image 3 of 3
      • Insert an opening pick in the seam between the lower case and chassis.
      • Slide the opening pick around the perimeter, prying every couple of centimeters as you go.
      • You will hear "snaps" of the lower case retaining clips releasing.
      • Continue prying around the entire perimeter until the lower case fully releases.
      • Lift off the lower case.
      Ask FixBot
Connor Bassolino
26,156 Reputation
125 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 69
All Time: 436
