HP Stream 14-CB174WM Battery Replacement
    1. HP Stream 14-CB174WM Battery Replacement, Lower Case: step 1, image 1 of 2 HP Stream 14-CB174WM Battery Replacement, Lower Case: step 1, image 2 of 2
      • Use an opening pick to gently pry up the edge of the rubber foot.
      • Grab the lifted edge of the foot and gently pull it away.
      • Repeat for the other rubber foot.
      • The oils on your skin can damage the adhesive on the rubber feet. Try not to touch the adhesive part of the feet with your hands.
      Ask FixBot
    2. HP Stream 14-CB174WM Battery Replacement: step 2, image 1 of 2 HP Stream 14-CB174WM Battery Replacement: step 2, image 2 of 2
      • Use a Phillips screwdriver to remove the eight 6.6 mm screws that secure the lower case.
      Ask FixBot
    3. HP Stream 14-CB174WM Battery Replacement: step 3, image 1 of 3 HP Stream 14-CB174WM Battery Replacement: step 3, image 2 of 3 HP Stream 14-CB174WM Battery Replacement: step 3, image 3 of 3
      • Insert an opening pick in the seam between the lower case and chassis.
      • Slide the opening pick around the perimeter, prying every couple of centimeters as you go.
      • You will hear "snaps" of the lower case retaining clips releasing.
      • Continue prying around the entire perimeter until the lower case fully releases.
      • Lift off the lower case.
      Ask FixBot
    1. HP Stream 14-CB174WM Battery Replacement, Battery: step 4, image 1 of 3 HP Stream 14-CB174WM Battery Replacement, Battery: step 4, image 2 of 3 HP Stream 14-CB174WM Battery Replacement, Battery: step 4, image 3 of 3
      • Remove the following Phillips screws that secure the battery:
      • Three 2.9 mm
      • Two 6.8 mm
      • Be sure to keep different screw types separate from one another throughout the battery removal process.
      Ask FixBot
    2. HP Stream 14-CB174WM Battery Replacement: step 5, image 1 of 2 HP Stream 14-CB174WM Battery Replacement: step 5, image 2 of 2
      • Use your fingers or the point of a spudger to slowly “wiggle” the battery connector directly out of its socket.
      • Do not pull on the wires.
      Ask FixBot
    3. HP Stream 14-CB174WM Battery Replacement: step 6, image 1 of 2 HP Stream 14-CB174WM Battery Replacement: step 6, image 2 of 2
      • Gently unseat the battery connector wire out from under the two plastic tabs.
      Ask FixBot
    4. HP Stream 14-CB174WM Battery Replacement: step 7, image 1 of 2 HP Stream 14-CB174WM Battery Replacement: step 7, image 2 of 2
      • Lift the battery up and out of the laptop.
      • The battery should lift out with very little effort. If the battery cannot easily be lifted out of the laptop chassis, check to see if you missed any screws.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 97
All Time: 1,472
