Up to 20% off select tools
HP Stream 13-c110nr WLAN Module Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
18
Past 30 Days:
55
All Time:
615
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
The WLAN repair guide will assist the user in removal and installation of the WLAN module for the HP Stream 13-c110nr.
    1. HP Stream 13-c110nr WLAN Module Replacement, Keyboard Assembly: step 1, image 1 of 1
      • Close the device.
      • Remove AC adapter plug from electrical outlet.
      • Remove AC adapter from device.
      • Turn the device off.
      • Unplug all external devices from device.
      • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
      Ask FixBot
    2. HP Stream 13-c110nr WLAN Module Replacement: step 2, image 1 of 1
      • Turn the device upside down with the back facing towards you.
      Ask FixBot
    3. HP Stream 13-c110nr WLAN Module Replacement: step 3, image 1 of 3 HP Stream 13-c110nr WLAN Module Replacement: step 3, image 2 of 3 HP Stream 13-c110nr WLAN Module Replacement: step 3, image 3 of 3
      • Use a pick to remove the two (2) large computer feet along the back edge of the device.
      • Use a pick to remove the two (2) small computer feet.
      • Use a pick to remove the one (1) screw cover.
      • Place rubber computer feet in safe place for reassembly.
      Ask FixBot
    4. HP Stream 13-c110nr WLAN Module Replacement: step 4, image 1 of 3 HP Stream 13-c110nr WLAN Module Replacement: step 4, image 2 of 3 HP Stream 13-c110nr WLAN Module Replacement: step 4, image 3 of 3
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
      • Place the thirteen (13) screws on magnetic mat for reassembly.
      Ask FixBot
    5. HP Stream 13-c110nr WLAN Module Replacement: step 5, image 1 of 1
      • Turn the device over with the front facing towards you.
      • Open the device as shown.
      Ask FixBot
    6. HP Stream 13-c110nr WLAN Module Replacement: step 6, image 1 of 3 HP Stream 13-c110nr WLAN Module Replacement: step 6, image 2 of 3 HP Stream 13-c110nr WLAN Module Replacement: step 6, image 3 of 3
      • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
      • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
      Ask FixBot
    7. HP Stream 13-c110nr WLAN Module Replacement: step 7, image 1 of 1
      • Disconnect the Touchpad cable.
      Ask FixBot
    8. HP Stream 13-c110nr WLAN Module Replacement: step 8, image 1 of 2 HP Stream 13-c110nr WLAN Module Replacement: step 8, image 2 of 2
      • Disconnect the Keyboard Cable.
      Ask FixBot
    9. HP Stream 13-c110nr WLAN Module Replacement: step 9, image 1 of 2 HP Stream 13-c110nr WLAN Module Replacement: step 9, image 2 of 2
      • Disconnect the Power connector cable.
      Ask FixBot
    10. HP Stream 13-c110nr WLAN Module Replacement: step 10, image 1 of 1
      • Remove the Keyboard/Top Cover from the device.
      Ask FixBot
    1. HP Stream 13-c110nr WLAN Module Replacement, WLAN Module: step 11, image 1 of 2 HP Stream 13-c110nr WLAN Module Replacement, WLAN Module: step 11, image 2 of 2
      • Disconnect the WLAN antenna cable from the WLAN module.
      Ask FixBot
    2. HP Stream 13-c110nr WLAN Module Replacement: step 12, image 1 of 1
      • Remove one (1) Phillips P0 PM2.0x3.0 mm screw.
      • Place one (1) screw on magnetic mat for reassembly.
      Ask FixBot
    3. HP Stream 13-c110nr WLAN Module Replacement: step 13, image 1 of 1
      • Remove the WLAN Module from device.
      Ask FixBot
Author
with
Stacey Deel
1,159 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 55
All Time: 615
