HP Stream 13-c110nr Touchpad Assembly Replacement
    1. HP Stream 13-c110nr Touchpad Assembly Replacement, Keyboard Assembly: step 1, image 1 of 1
      • Close the device.
      • Remove AC adapter plug from electrical outlet.
      • Remove AC adapter from device.
      • Turn the device off.
      • Unplug all external devices from device.
      • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
      Ask FixBot
    2. HP Stream 13-c110nr Touchpad Assembly Replacement: step 2, image 1 of 1
      • Turn the device upside down with the back facing towards you.
      Ask FixBot
    3. HP Stream 13-c110nr Touchpad Assembly Replacement: step 3, image 1 of 3 HP Stream 13-c110nr Touchpad Assembly Replacement: step 3, image 2 of 3 HP Stream 13-c110nr Touchpad Assembly Replacement: step 3, image 3 of 3
      • Use a pick to remove the two (2) large computer feet along the back edge of the device.
      • Use a pick to remove the two (2) small computer feet.
      • Use a pick to remove the one (1) screw cover.
      • Place rubber computer feet in safe place for reassembly.
      Ask FixBot
    4. HP Stream 13-c110nr Touchpad Assembly Replacement: step 4, image 1 of 3 HP Stream 13-c110nr Touchpad Assembly Replacement: step 4, image 2 of 3 HP Stream 13-c110nr Touchpad Assembly Replacement: step 4, image 3 of 3
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
      • Place the thirteen (13) screws on magnetic mat for reassembly.
      Ask FixBot
    5. HP Stream 13-c110nr Touchpad Assembly Replacement: step 5, image 1 of 1
      • Turn the device over with the front facing towards you.
      • Open the device as shown.
      Ask FixBot
    6. HP Stream 13-c110nr Touchpad Assembly Replacement: step 6, image 1 of 3 HP Stream 13-c110nr Touchpad Assembly Replacement: step 6, image 2 of 3 HP Stream 13-c110nr Touchpad Assembly Replacement: step 6, image 3 of 3
      • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
      • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
      Ask FixBot
    7. HP Stream 13-c110nr Touchpad Assembly Replacement: step 7, image 1 of 1
      • Disconnect the Touchpad cable.
      Ask FixBot
    8. HP Stream 13-c110nr Touchpad Assembly Replacement: step 8, image 1 of 2 HP Stream 13-c110nr Touchpad Assembly Replacement: step 8, image 2 of 2
      • Disconnect the Keyboard Cable.
      Ask FixBot
    9. HP Stream 13-c110nr Touchpad Assembly Replacement: step 9, image 1 of 2 HP Stream 13-c110nr Touchpad Assembly Replacement: step 9, image 2 of 2
      • Disconnect the Power connector cable.
      Ask FixBot
    10. HP Stream 13-c110nr Touchpad Assembly Replacement: step 10, image 1 of 1
      • Remove the Keyboard/Top Cover from the device.
      Ask FixBot
    1. HP Stream 13-c110nr Touchpad Assembly Replacement, Touchpad Assembly: step 11, image 1 of 2 HP Stream 13-c110nr Touchpad Assembly Replacement, Touchpad Assembly: step 11, image 2 of 2
      • Place the Top Cover/Keyboard assembly face down with the front towards you.
      Ask FixBot
    2. HP Stream 13-c110nr Touchpad Assembly Replacement: step 12, image 1 of 2 HP Stream 13-c110nr Touchpad Assembly Replacement: step 12, image 2 of 2
      • Remove the TouchPad cable.
      Ask FixBot
    3. HP Stream 13-c110nr Touchpad Assembly Replacement: step 13, image 1 of 1
      • Remove two (2) Phillips P0 PM2.5x3.0 mm screws from Touchpad assembly.
      • Place two (2) screws on magnetic mat for reassembly.
      Ask FixBot
    4. HP Stream 13-c110nr Touchpad Assembly Replacement: step 14, image 1 of 3 HP Stream 13-c110nr Touchpad Assembly Replacement: step 14, image 2 of 3 HP Stream 13-c110nr Touchpad Assembly Replacement: step 14, image 3 of 3
      • Use the plastic pick to pry up the black TouchPad cover from the blue top cover.
      • The TouchPad cover is molded to the Top Cover/Keyboard. Slight pressure must be maintained to release the cover.
      • A popping noise may be heard when prying the touchpad cover off of the top cover.
      Ask FixBot
    5. HP Stream 13-c110nr Touchpad Assembly Replacement: step 15, image 1 of 2 HP Stream 13-c110nr Touchpad Assembly Replacement: step 15, image 2 of 2
      • Remove the Touchpad assembly from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 57
All Time: 441
