HP Stream 13-c110nr Battery Assembly Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
62
All Time:
1,376
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The Battery Assembly repair guide will assist the user in the removal and installation procedures within the HP Stream 13-c110nr (ENERGY STAR). Over time, laptop batteries naturally degrade, leading to reduced charge capacity and shorter usage times. Replacing the battery can resolve power-related issues and restore your laptop’s portability.
You may need to replace the battery if you experience:
  • Rapid battery drain
  • The laptop shutting off unexpectedly
  • Failure to charge or power on
The battery is a crucial component, and proper handling is essential. If your battery is swollen, take appropriate precautions, as it poses a fire risk. Refer to iFixit’s Swollen Battery Guide for guidance.
Before starting, power down your laptop completely and disconnect it from any power source. Follow this guide step-by-step to safely replace the battery and get your HP Stream 13-c110nr running smoothly again.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. HP Stream 13-c110nr Battery Assembly Replacement, Keyboard Assembly: step 1, image 1 of 1
      • Close the device.
      • Remove AC adapter plug from electrical outlet.
      • Remove AC adapter from device.
      • Turn the device off.
      • Unplug all external devices from device.
      • If you are unsure whether the computer is off or in hibernation mode, start the computer and then shutdown the operating system.
      Ask FixBot
    2. HP Stream 13-c110nr Battery Assembly Replacement: step 2, image 1 of 1
      • Turn the device upside down with the back facing towards you.
      Ask FixBot
    3. HP Stream 13-c110nr Battery Assembly Replacement: step 3, image 1 of 3 HP Stream 13-c110nr Battery Assembly Replacement: step 3, image 2 of 3 HP Stream 13-c110nr Battery Assembly Replacement: step 3, image 3 of 3
      • Use a pick to remove the two (2) large computer feet along the back edge of the device.
      • Use a pick to remove the two (2) small computer feet.
      • Use a pick to remove the one (1) screw cover.
      • Place rubber computer feet in safe place for reassembly.
      Ask FixBot
    4. HP Stream 13-c110nr Battery Assembly Replacement: step 4, image 1 of 3 HP Stream 13-c110nr Battery Assembly Replacement: step 4, image 2 of 3 HP Stream 13-c110nr Battery Assembly Replacement: step 4, image 3 of 3
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
      • Place the thirteen (13) screws on magnetic mat for reassembly.
      Ask FixBot
    5. HP Stream 13-c110nr Battery Assembly Replacement: step 5, image 1 of 1
      • Turn the device over with the front facing towards you.
      • Open the device as shown.
      Ask FixBot
    6. HP Stream 13-c110nr Battery Assembly Replacement: step 6, image 1 of 3 HP Stream 13-c110nr Battery Assembly Replacement: step 6, image 2 of 3 HP Stream 13-c110nr Battery Assembly Replacement: step 6, image 3 of 3
      • Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
      • Do not completely remove the Keyboard/Top cover from the Bottom cover yet.
      Ask FixBot
    7. HP Stream 13-c110nr Battery Assembly Replacement: step 7, image 1 of 1
      • Disconnect the Touchpad cable.
      Ask FixBot
    8. HP Stream 13-c110nr Battery Assembly Replacement: step 8, image 1 of 2 HP Stream 13-c110nr Battery Assembly Replacement: step 8, image 2 of 2
      • Disconnect the Keyboard Cable.
      Ask FixBot
    9. HP Stream 13-c110nr Battery Assembly Replacement: step 9, image 1 of 2 HP Stream 13-c110nr Battery Assembly Replacement: step 9, image 2 of 2
      • Disconnect the Power connector cable.
      Ask FixBot
    10. HP Stream 13-c110nr Battery Assembly Replacement: step 10, image 1 of 1
      • Remove the Keyboard/Top Cover from the device.
      Ask FixBot
    1. HP Stream 13-c110nr Battery Assembly Replacement, Battery Assembly: step 11, image 1 of 2 HP Stream 13-c110nr Battery Assembly Replacement, Battery Assembly: step 11, image 2 of 2
      • Use a pick to detach the Battery assembly cable.
      Ask FixBot
    2. HP Stream 13-c110nr Battery Assembly Replacement: step 12, image 1 of 2 HP Stream 13-c110nr Battery Assembly Replacement: step 12, image 2 of 2
      • Remove eight (8) Phillips P0 PM2.0x3.0 mm screws from Battery assembly.
      • Place eight (8) screws on magnetic mat for reassembly.
      Ask FixBot
    3. HP Stream 13-c110nr Battery Assembly Replacement: step 13, image 1 of 1
      • Remove Battery Assembly from device.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 62
All Time: 1,376
