HP Stream 13-c010nr USB Port Replacement
    1. HP Stream 13-c010nr USB Port Replacement, laptop: step 1, image 1 of 1
      • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
      Ask FixBot
    2. HP Stream 13-c010nr USB Port Replacement: step 2, image 1 of 2 HP Stream 13-c010nr USB Port Replacement: step 2, image 2 of 2
      • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
      Ask FixBot
    3. HP Stream 13-c010nr USB Port Replacement: step 3, image 1 of 2 HP Stream 13-c010nr USB Port Replacement: step 3, image 2 of 2
      • Flip the laptop over and open it up.
      • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
      • Lift up the keyboard.
      • Ribbon cables still connect the two pieces.
      Ask FixBot
    4. HP Stream 13-c010nr USB Port Replacement: step 4, image 1 of 1
      • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
      • Pull up the ribbon cables from their sockets.
      Ask FixBot
    1. HP Stream 13-c010nr USB Port Replacement, USB Port: step 5, image 1 of 2 HP Stream 13-c010nr USB Port Replacement, USB Port: step 5, image 2 of 2
      • Use a spudger to flip up the retaining flap on the USB port ribbon cable ZIF socket.
      • Pull the ribbon cable out of the socket.
      Ask FixBot
    2. HP Stream 13-c010nr USB Port Replacement: step 6, image 1 of 2 HP Stream 13-c010nr USB Port Replacement: step 6, image 2 of 2
      • Remove the three 3mm Phillips #0 screws from the USB port.
      • Pull out the USB port.
      Ask FixBot
    3. HP Stream 13-c010nr USB Port Replacement: step 7, image 1 of 1
      • Remove the chip containing the two USB Ports.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Keegan Lapham
759 Reputation
6 Guides authored
USF Tampa, Team S1-G3, Cagle Spring 2018 Member of USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 72
All Time: 770
