Up to 20% off select tools
HP Stream 13-c010nr Disassembly
Views: 5.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
30
Past 30 Days:
107
All Time:
5,469
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to disassemble a HP Stream 13-c010nr laptop.
    1. HP Stream 13-c010nr Disassembly, laptop: step 1, image 1 of 1
      • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
      Ask FixBot
    2. HP Stream 13-c010nr Disassembly: step 2, image 1 of 2 HP Stream 13-c010nr Disassembly: step 2, image 2 of 2
      • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
      Ask FixBot
    3. HP Stream 13-c010nr Disassembly: step 3, image 1 of 2 HP Stream 13-c010nr Disassembly: step 3, image 2 of 2
      • Flip the laptop over and open it up.
      • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
      • Lift up the keyboard.
      • Ribbon cables still connect the two pieces.
      Ask FixBot
    4. HP Stream 13-c010nr Disassembly: step 4, image 1 of 1
      • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
      • Pull up the ribbon cables from their sockets.
      Ask FixBot
2 other people completed this guide.
Author
with
Keegan Lapham
759 Reputation
6 Guides authored
USF Tampa, Team S1-G3, Cagle Spring 2018 Member of USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 107
All Time: 5,469
