HP Stream 13-c010nr Battery Replacement
    1. HP Stream 13-c010nr Battery Replacement, laptop: step 1, image 1 of 1
      • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
      Ask FixBot
    2. HP Stream 13-c010nr Battery Replacement: step 2, image 1 of 2 HP Stream 13-c010nr Battery Replacement: step 2, image 2 of 2
      • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
      Ask FixBot
    3. HP Stream 13-c010nr Battery Replacement: step 3, image 1 of 2 HP Stream 13-c010nr Battery Replacement: step 3, image 2 of 2
      • Flip the laptop over and open it up.
      • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
      • Lift up the keyboard.
      • Ribbon cables still connect the two pieces.
      Ask FixBot
    4. HP Stream 13-c010nr Battery Replacement: step 4, image 1 of 1
      • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
      • Pull up the ribbon cables from their sockets.
      Ask FixBot
    1. HP Stream 13-c010nr Battery Replacement, Battery: step 5, image 1 of 2 HP Stream 13-c010nr Battery Replacement, Battery: step 5, image 2 of 2
      • Remove the eight 5mm Phillips #0 screws from the battery.
      • Disconnect the battery from the motherboard.
      • Pull the battery up and out of the laptop.
      Ask FixBot
Keegan Lapham
759 Reputation
6 Guides authored
USF Tampa, Team S1-G3, Cagle Spring 2018 Member of USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 74
All Time: 2,347
