Better Introduction
Improve this guide by completing or revising its introduction.
Student In Progress
This guide is being worked on by hardworking students.
Parts
Tools
Introduction
Go to step 1 ↓This guide covers the accessing and replacing of the wireless card in an HP Stream 13-c002dx. We all use technology nowadays that repairing is a needed action and important skill to longevity to your devices. The repair being made is done in the most crucial area of a computer component and a simple mistake could complicate other function in the computer. The wireless card is in charge for the use of the wifi connection and bluetooth, these two are things that we all use in every day life in work, school, and entertainment. To make the repair is to review what one must remove and the steps to replace the necessary piece without getting confused were what components go where since one mistake could cause it not to work.
Flip the laptop over so the bottom is facing up.
Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing.
Attached to the Wi-Fi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the Wi-Fi card.
Once the wire is removed, set it aside so it does not get damaged.
