HP Stream 13-c002dx Keyboard Replacement
    1. HP Stream 13-c002dx Keyboard Replacement, Keyboard: step 1, image 1 of 2 HP Stream 13-c002dx Keyboard Replacement, Keyboard: step 1, image 2 of 2
      • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
      • Flip the laptop over so the bottom is facing up.
      • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
      • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
      • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
      Ask FixBot
    2. HP Stream 13-c002dx Keyboard Replacement: step 2, image 1 of 3 HP Stream 13-c002dx Keyboard Replacement: step 2, image 2 of 3 HP Stream 13-c002dx Keyboard Replacement: step 2, image 3 of 3
      • Flip the laptop back over so it's right side up and open the screen.
      • Using a spudger, separate the keyboard surface from the bottom of the laptop.
      • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
      • Remove the keyboard assembly.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 57
All Time: 1,308
