Introduction
Go to step 1 ↓Use this guide to replace the battery in your HP Stream 13-c002dx. You may need to replace the battery in your HP Stream if it is having overheating issues or is unable to hold a charge. The tools required are listed below, but before beginning make sure the device is completely powered off and disconnected from any external power sources.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Spudger4.9
Flip the laptop over so the bottom is facing up.
Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
Use the Phillips #0 to remove four screws from the top of the battery labeled A.
Use the Phillips #0 screwdriver to remove four screws labeled holding the battery to the case.
2 other people completed this guide.
