Up to 20% off select tools
HP Stream 13 Battery Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
96
All Time:
2,239
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Quick 10min guide on how to replace the battery on the HP Stream 13
Video Overview
    1. HP Stream 13 Battery Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop over
      Ask FixBot
    2. HP Stream 13 Battery Replacement: step 2, image 1 of 2 HP Stream 13 Battery Replacement: step 2, image 2 of 2
      • Remove the five screw covers across the back edge of the laptop
      • Remove the 13 screws that hold the base in place.
      Ask FixBot
    3. HP Stream 13 Battery Replacement: step 3, image 1 of 1
      • Carefully pry up around the edges of the laptop. Take your time around the ports as they can easily get damaged.
      Ask FixBot
    4. HP Stream 13 Battery Replacement: step 4, image 1 of 2 HP Stream 13 Battery Replacement: step 4, image 2 of 2
      • Slowly lift the top case/keyboard upwards and disconnect the three ribbon cables.
      Ask FixBot
    5. HP Stream 13 Battery Replacement: step 5, image 1 of 2 HP Stream 13 Battery Replacement: step 5, image 2 of 2
      • Disconnect the battery from the main board.
      • Unscrew the 8 screws holding the battery in place.
      Ask FixBot
    6. HP Stream 13 Battery Replacement: step 6, image 1 of 1
      • Lift the battery out and you're done.
      Ask FixBot
2 other people completed this guide.
Author
with
Nick Myers
5,977 Reputation
38 Guides authored
1 Guide Comment
Where can I find a replacement battery for hp stream notebook pc 13 c12Onr. I have looked everywhere and no luck. Is there another one that is compatible? Thanks!
Sarah - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 96
All Time: 2,239
