HP Stream 11-y010nr Keyboard Replacement
    1. HP Stream 11-y010nr Keyboard Replacement, Keyboard: step 1, image 1 of 3 HP Stream 11-y010nr Keyboard Replacement, Keyboard: step 1, image 2 of 3 HP Stream 11-y010nr Keyboard Replacement, Keyboard: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
      • Ensure the laptop is turned off.
      Ask FixBot
    2. HP Stream 11-y010nr Keyboard Replacement: step 2, image 1 of 2 HP Stream 11-y010nr Keyboard Replacement: step 2, image 2 of 2
      • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
      Ask FixBot
    3. HP Stream 11-y010nr Keyboard Replacement: step 3, image 1 of 2 HP Stream 11-y010nr Keyboard Replacement: step 3, image 2 of 2
      • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
      • Go all the way around the laptop.
      Ask FixBot
    4. HP Stream 11-y010nr Keyboard Replacement: step 4, image 1 of 1
      • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
      • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
      Ask FixBot
    5. HP Stream 11-y010nr Keyboard Replacement: step 5, image 1 of 3 HP Stream 11-y010nr Keyboard Replacement: step 5, image 2 of 3 HP Stream 11-y010nr Keyboard Replacement: step 5, image 3 of 3
      • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
      • Remove the keyboard.
      Ask FixBot
To reassemble your device, follow these instructions.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 70
All Time: 1,057
