HP Stream 11-y010nr Battery Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
94
All Time:
5,090
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Are you are having problems with your HP Stream 11-y010nr battery? Is the battery life bad enough that it needs to be replaced? The first thing that you should do is see our troubleshooting page and check it before the battery gets replaced. HP Stream 11-y010nr Troubleshooting
This guide will take you through the necessary steps to properly remove and replace the battery. Use caution when taking the battery out as it can catch on fire if the battery pack is punctured. Additionally, a thin wire is attached to the bottom of the battery so use caution when taking it out.
Prior to beginning, ensure the laptop is completely powered off such that it will not interfere with the steps in this guide.
Parts
Tools
    1. HP Stream 11-y010nr Battery Replacement, Keyboard: step 1, image 1 of 3 HP Stream 11-y010nr Battery Replacement, Keyboard: step 1, image 2 of 3 HP Stream 11-y010nr Battery Replacement, Keyboard: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
      • Ensure the laptop is turned off.
      Ask FixBot
    2. HP Stream 11-y010nr Battery Replacement: step 2, image 1 of 2 HP Stream 11-y010nr Battery Replacement: step 2, image 2 of 2
      • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
      Ask FixBot
    3. HP Stream 11-y010nr Battery Replacement: step 3, image 1 of 2 HP Stream 11-y010nr Battery Replacement: step 3, image 2 of 2
      • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
      • Go all the way around the laptop.
      Ask FixBot
    4. HP Stream 11-y010nr Battery Replacement: step 4, image 1 of 1
      • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
      • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
      Ask FixBot
    5. HP Stream 11-y010nr Battery Replacement: step 5, image 1 of 3 HP Stream 11-y010nr Battery Replacement: step 5, image 2 of 3 HP Stream 11-y010nr Battery Replacement: step 5, image 3 of 3
      • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
      • Remove the keyboard.
      Ask FixBot
    1. HP Stream 11-y010nr Battery Replacement, Battery: step 6, image 1 of 3 HP Stream 11-y010nr Battery Replacement, Battery: step 6, image 2 of 3 HP Stream 11-y010nr Battery Replacement, Battery: step 6, image 3 of 3
      • Use your fingers or a spudger to pull the battery cable out from its connector.
      Ask FixBot
    2. HP Stream 11-y010nr Battery Replacement: step 7, image 1 of 2 HP Stream 11-y010nr Battery Replacement: step 7, image 2 of 2
      • Unscrew the six 0.4mm screws surrounding the battery with a Phillips #1 screwdriver.
      Ask FixBot
    3. HP Stream 11-y010nr Battery Replacement: step 8, image 1 of 3 HP Stream 11-y010nr Battery Replacement: step 8, image 2 of 3 HP Stream 11-y010nr Battery Replacement: step 8, image 3 of 3
      • Carefully lift up on the battery.
      • If the black and white wire on the bottom is intertwined with the bracket, gently pull the wire off the battery.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 94
All Time: 5,090
