HP Stream 11-r020nr Battery Replacement
    1. HP Stream 11-r020nr Battery Replacement, Battery: step 1, image 1 of 2 HP Stream 11-r020nr Battery Replacement, Battery: step 1, image 2 of 2
      • Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
      • Turn the device top down so the rubber feet are facing up.
      • Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. This will uncover 6 screws for a total of 11 screws.
      Ask FixBot
    2. HP Stream 11-r020nr Battery Replacement: step 2, image 1 of 1
      • Using the Phillips #1 screwdriver, remove all eleven of the 5mm screws.
      Ask FixBot
    3. HP Stream 11-r020nr Battery Replacement: step 3, image 1 of 2 HP Stream 11-r020nr Battery Replacement: step 3, image 2 of 2
      • Flip the laptop over and open.
      • Using the blue plastic opening tool, separate the keyboard plate from the main body by prying up starting around the bottom corners, prying the bottom up and all the way around the whole keyboard plate.
      Ask FixBot
    4. HP Stream 11-r020nr Battery Replacement: step 4, image 1 of 2 HP Stream 11-r020nr Battery Replacement: step 4, image 2 of 2
      • Use the black nylon spudger to flip the black tab up that holds the ribbon cable in place.
      • Lift the ribbon cable free.
      Ask FixBot
    5. HP Stream 11-r020nr Battery Replacement: step 5, image 1 of 2 HP Stream 11-r020nr Battery Replacement: step 5, image 2 of 2
      • Use the black nylon spudger to flip the black tab up that holds the large ribbon cable in place.
      • Pull the ribbon cable free from the base of the keyboard.
      Ask FixBot
    6. HP Stream 11-r020nr Battery Replacement: step 6, image 1 of 2 HP Stream 11-r020nr Battery Replacement: step 6, image 2 of 2
      • Remove the tape covering the ribbon cable.
      • Pull the ribbon cable away from the base of the laptop.
      Ask FixBot
    7. HP Stream 11-r020nr Battery Replacement: step 7, image 1 of 1
      • After detaching the two large ribbon cables, carefully lean the keyboard against the screen.
      Ask FixBot
    8. HP Stream 11-r020nr Battery Replacement: step 8, image 1 of 1
      • With the black nylon spudger lift the small circular battery off of the main battery.
      Ask FixBot
    9. HP Stream 11-r020nr Battery Replacement: step 9, image 1 of 1
      • Lift the battery cable free from the motherboard with your fingers.
      Ask FixBot
    10. HP Stream 11-r020nr Battery Replacement: step 10, image 1 of 2 HP Stream 11-r020nr Battery Replacement: step 10, image 2 of 2
      • Gently pull the wire away from the battery.
      • Using the Phillips #1 screwdriver, remove the six 3mm screws.
      Ask FixBot
    11. HP Stream 11-r020nr Battery Replacement: step 11, image 1 of 1
      • Gently lift and pull the battery out of the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 84
All Time: 4,484
