HP Stream 11-d020nr Webcam Replacement
    1. HP Stream 11-d020nr Webcam Replacement, Lower Case: step 1, image 1 of 3 HP Stream 11-d020nr Webcam Replacement, Lower Case: step 1, image 2 of 3 HP Stream 11-d020nr Webcam Replacement, Lower Case: step 1, image 3 of 3
      • Before disassembly, unplug and power off the Stream 11.
      • Pry off the two elliptical rubber inserts (one in each corner).
      • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
      Ask FixBot
    2. HP Stream 11-d020nr Webcam Replacement: step 2, image 1 of 2 HP Stream 11-d020nr Webcam Replacement: step 2, image 2 of 2
      • Remove the eleven 5.6 mm Phillips #00 screws.
      Ask FixBot
    3. HP Stream 11-d020nr Webcam Replacement: step 3, image 1 of 3 HP Stream 11-d020nr Webcam Replacement: step 3, image 2 of 3 HP Stream 11-d020nr Webcam Replacement: step 3, image 3 of 3
      • Turn the computer upright and lift the screen.
      • Carefully use a spudger to pry the plastic keyboard cover from the base.
      • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
      • Work the spudger around the cover to release the clips attaching the cover to the base.
      • Be patient when removing the cover, as there are many clips and it may take some time.
      Ask FixBot
    4. HP Stream 11-d020nr Webcam Replacement: step 4, image 1 of 3 HP Stream 11-d020nr Webcam Replacement: step 4, image 2 of 3 HP Stream 11-d020nr Webcam Replacement: step 4, image 3 of 3
      • Disconnect the cable connecting the ClickPad to the base.
      • Remove the plastic keyboard cover.
      • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
      Ask FixBot
    1. HP Stream 11-d020nr Webcam Replacement, Keyboard: step 5, image 1 of 2 HP Stream 11-d020nr Webcam Replacement, Keyboard: step 5, image 2 of 2
      • Tilt the top of the keyboard plate up until you separate it from the base.
      • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
      Ask FixBot
    2. HP Stream 11-d020nr Webcam Replacement: step 6, image 1 of 3 HP Stream 11-d020nr Webcam Replacement: step 6, image 2 of 3 HP Stream 11-d020nr Webcam Replacement: step 6, image 3 of 3
      • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
      • After disengaging the connectors, gently unplug both ribbon cables.
      Ask FixBot
    1. HP Stream 11-d020nr Webcam Replacement, Lid: step 7, image 1 of 3 HP Stream 11-d020nr Webcam Replacement, Lid: step 7, image 2 of 3 HP Stream 11-d020nr Webcam Replacement, Lid: step 7, image 3 of 3
      • Lift the black flap on the display cable ZIF connector.
      • After lifting the flap, gently pull the display cable from its socket.
      • Disconnect the wireless antenna from the wireless card.
      • Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
      Ask FixBot
    2. HP Stream 11-d020nr Webcam Replacement: step 8, image 1 of 3 HP Stream 11-d020nr Webcam Replacement: step 8, image 2 of 3 HP Stream 11-d020nr Webcam Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the screw covers from the lid.
      • Remove the two 2.2 mm Phillips #000 screws.
      • Use a plastic opening tool to disengage the front part of the lid.
      Ask FixBot
    1. HP Stream 11-d020nr Webcam Replacement, Webcam: step 9, image 1 of 1
      Buy
      • Use the tweezers to remove the wire connected to the webcam.
      Ask FixBot
    2. HP Stream 11-d020nr Webcam Replacement: step 10, image 1 of 1
      • Use the tweezers to pull the webcam off of the frame.
      Ask FixBot
2 other people completed this guide.
Spenser Mason
1,781 Reputation
6 Guides authored
USF Tampa, Team 3-5, Wollert Spring 2016 Member of USF Tampa, Team 3-5, Wollert Spring 2016
USFT-WOLLERT-S16S3G5
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 92
All Time: 857
