Up to 20% off select tools
HP Stream 11-d020nr Screen Replacement
Views: 6.7K
View statistics:
Past 24 Hours:
11
Past 7 Days:
28
Past 30 Days:
91
All Time:
6,711
Comments: 2
2 comments on steps.
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a faulty or damaged screen in an HP Stream 11 laptop. This should take you about 10-15 minutes. There are hidden screws under plastic covers that inhibit your ability to remove the screen and could damage your screen. Once these screws are removed it is fairly simple to remove your screen.
    1. HP Stream 11-d020nr Screen Replacement, Lower Case: step 1, image 1 of 3 HP Stream 11-d020nr Screen Replacement, Lower Case: step 1, image 2 of 3 HP Stream 11-d020nr Screen Replacement, Lower Case: step 1, image 3 of 3
      • Before disassembly, unplug and power off the Stream 11.
      • Pry off the two elliptical rubber inserts (one in each corner).
      • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
      Ask FixBot
    2. HP Stream 11-d020nr Screen Replacement: step 2, image 1 of 2 HP Stream 11-d020nr Screen Replacement: step 2, image 2 of 2
      • Remove the eleven 5.6 mm Phillips #00 screws.
      Ask FixBot
    3. HP Stream 11-d020nr Screen Replacement: step 3, image 1 of 3 HP Stream 11-d020nr Screen Replacement: step 3, image 2 of 3 HP Stream 11-d020nr Screen Replacement: step 3, image 3 of 3
      • Turn the computer upright and lift the screen.
      • Carefully use a spudger to pry the plastic keyboard cover from the base.
      • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
      • Work the spudger around the cover to release the clips attaching the cover to the base.
      • Be patient when removing the cover, as there are many clips and it may take some time.
      Ask FixBot
    4. HP Stream 11-d020nr Screen Replacement: step 4, image 1 of 3 HP Stream 11-d020nr Screen Replacement: step 4, image 2 of 3 HP Stream 11-d020nr Screen Replacement: step 4, image 3 of 3
      • Disconnect the cable connecting the ClickPad to the base.
      • Remove the plastic keyboard cover.
      • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
      Ask FixBot
    1. HP Stream 11-d020nr Screen Replacement, Keyboard: step 5, image 1 of 2 HP Stream 11-d020nr Screen Replacement, Keyboard: step 5, image 2 of 2
      • Tilt the top of the keyboard plate up until you separate it from the base.
      • Tilt the keyboard toward you slowly but do not remove it, it is still connected with ribbon cables.
      Ask FixBot
    2. HP Stream 11-d020nr Screen Replacement: step 6, image 1 of 3 HP Stream 11-d020nr Screen Replacement: step 6, image 2 of 3 HP Stream 11-d020nr Screen Replacement: step 6, image 3 of 3
      • Lift up the retaining flaps on the ZIF connectors securing the two keyboard ribbon cables.
      • After disengaging the connectors, gently unplug both ribbon cables.
      Ask FixBot
    1. HP Stream 11-d020nr Screen Replacement, Lid: step 7, image 1 of 3 HP Stream 11-d020nr Screen Replacement, Lid: step 7, image 2 of 3 HP Stream 11-d020nr Screen Replacement, Lid: step 7, image 3 of 3
      • Lift the black flap on the display cable ZIF connector.
      • After lifting the flap, gently pull the display cable from its socket.
      • Disconnect the wireless antenna from the wireless card.
      • Remove the four 2.2 mm Phillips #00 screws on the left and right sides of the laptop.
      Ask FixBot
    2. HP Stream 11-d020nr Screen Replacement: step 8, image 1 of 3 HP Stream 11-d020nr Screen Replacement: step 8, image 2 of 3 HP Stream 11-d020nr Screen Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to remove the screw covers from the lid.
      • Remove the two 2.2 mm Phillips #000 screws.
      • Use a plastic opening tool to disengage the front part of the lid.
      Ask FixBot
    1. HP Stream 11-d020nr Screen Replacement, Screen: step 9, image 1 of 2 HP Stream 11-d020nr Screen Replacement, Screen: step 9, image 2 of 2
      • Unscrew the four 3.3mm Phillips #000 screws as indicated.
      • Lift the screen from the lid carefully.
      Ask FixBot
11 other people completed this guide.
Author
with
Spenser Mason
1,781 Reputation
6 Guides authored
USF Tampa, Team 3-5, Wollert Spring 2016 Member of USF Tampa, Team 3-5, Wollert Spring 2016
USFT-WOLLERT-S16S3G5
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 28
Past 30 Days: 91
All Time: 6,711
