HP Stream 11-d020nr Lower Case Replacement
    1. HP Stream 11-d020nr Lower Case Replacement, Lower Case: step 1, image 1 of 3 HP Stream 11-d020nr Lower Case Replacement, Lower Case: step 1, image 2 of 3 HP Stream 11-d020nr Lower Case Replacement, Lower Case: step 1, image 3 of 3
      • Before disassembly, unplug and power off the Stream 11.
      • Pry off the two elliptical rubber inserts (one in each corner).
      • Pry off the two circular rubber inserts below the removed elliptical inserts (one in each corner).
      Ask FixBot
    2. HP Stream 11-d020nr Lower Case Replacement: step 2, image 1 of 2 HP Stream 11-d020nr Lower Case Replacement: step 2, image 2 of 2
      • Remove the eleven 5.6 mm Phillips #00 screws.
      Ask FixBot
    3. HP Stream 11-d020nr Lower Case Replacement: step 3, image 1 of 3 HP Stream 11-d020nr Lower Case Replacement: step 3, image 2 of 3 HP Stream 11-d020nr Lower Case Replacement: step 3, image 3 of 3
      • Turn the computer upright and lift the screen.
      • Carefully use a spudger to pry the plastic keyboard cover from the base.
      • When using the metal spudger, be careful not to press into the components underneath the keyboard cover. If possible, use a standard spudger or plastic opening tool to remove the keyboard cover.
      • Work the spudger around the cover to release the clips attaching the cover to the base.
      • Be patient when removing the cover, as there are many clips and it may take some time.
      Ask FixBot
    4. HP Stream 11-d020nr Lower Case Replacement: step 4, image 1 of 3 HP Stream 11-d020nr Lower Case Replacement: step 4, image 2 of 3 HP Stream 11-d020nr Lower Case Replacement: step 4, image 3 of 3
      • Disconnect the cable connecting the ClickPad to the base.
      • Remove the plastic keyboard cover.
      • The cover is attached to the ClickPad by a cable. Be careful not to lift the cover too far so you do not damage this cable.
      Ask FixBot
Ian Somerville
122 Reputation
1 Guide authored
USF Tampa, Team 3-5, Wollert Spring 2016 Member of USF Tampa, Team 3-5, Wollert Spring 2016
USFT-WOLLERT-S16S3G5
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 106
All Time: 2,388
