HP Stream 11-d008TU Heatsink Replacement
    1. HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: step 1, image 1 of 3 HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: step 1, image 2 of 3 HP Stream 11-d008TU Heatsink Replacement, Rubber Feet Removal: step 1, image 3 of 3
      • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
      • Repeat this process for the other side of the device
      • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
      Ask FixBot
    2. HP Stream 11-d008TU Heatsink Replacement, Screw removal: step 2, image 1 of 2 HP Stream 11-d008TU Heatsink Replacement, Screw removal: step 2, image 2 of 2
      • Remove the 11x 5mm Phillips PH-0 screws (circled)
      Ask FixBot
    3. HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: step 3, image 1 of 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: step 3, image 2 of 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard Unclipping: step 3, image 3 of 3
      • Use your finger to pry the outer blue shell over the keyboard
      • Continue this process around the edges of the device
      • You may have to use a prying tool to pry the harder edges such as around the I/O ports
      • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
      Ask FixBot
    4. HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: step 4, image 1 of 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: step 4, image 2 of 3 HP Stream 11-d008TU Heatsink Replacement, Keyboard removal: step 4, image 3 of 3
      • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
      • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
      • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
      • Your keyboard assembly is now safe to remove
      Ask FixBot
    1. HP Stream 11-d008TU Heatsink Replacement, Unscrew the heatsink: step 5, image 1 of 1
      • Unscrew the four 2.5mm M2x2.5 PH-0 Phillips head screws in reverse numerical order (4-3-2-1)
      • 4: Bottom left | 3: Top Right | 2: Bottom Right | 1: Top Left
      Ask FixBot
    2. HP Stream 11-d008TU Heatsink Replacement, Remove the heatsink: step 6, image 1 of 2 HP Stream 11-d008TU Heatsink Replacement, Remove the heatsink: step 6, image 2 of 2
      • Lift the heatsink
      Ask FixBot
Joel Taylor
1,376 Reputation
8 Guides authored
Australia Member of Australia
Community
4 Members
90 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 25
All Time: 374
