HP Sprocket 2-in-1 Flash Replacement
  1. HP Sprocket 2-in-1 Flash Replacement, Outer Casing: step 1, image 1 of 2 HP Sprocket 2-in-1 Flash Replacement, Outer Casing: step 1, image 2 of 2
    • Remove the back cover and any printer paper inside the device.
    Ask FixBot
  2. HP Sprocket 2-in-1 Flash Replacement: step 2, image 1 of 2 HP Sprocket 2-in-1 Flash Replacement: step 2, image 2 of 2
    • Using the Jimmy, slowly pry open the outer edge of the remaining white plastic on the back.
    • Remove the plastic from the device once it lifts out freely.
    Ask FixBot
  3. HP Sprocket 2-in-1 Flash Replacement: step 3, image 1 of 3 HP Sprocket 2-in-1 Flash Replacement: step 3, image 2 of 3 HP Sprocket 2-in-1 Flash Replacement: step 3, image 3 of 3
    • Remove two 2.5mm JIS #00 located on the small circuit board in view.
    • Use the Jimmy to remove the board after the screws have been removed.
    • Be careful not to crease or damage the ribbon cable.
    Ask FixBot
  4. HP Sprocket 2-in-1 Flash Replacement: step 4, image 1 of 3 HP Sprocket 2-in-1 Flash Replacement: step 4, image 2 of 3 HP Sprocket 2-in-1 Flash Replacement: step 4, image 3 of 3
    • Remove two 2.5mm JIS #00 screws from the translucent plastic bracket.
    • One will be located beneath the ribbon cable.
    • Remove the translucent plastic bracket by hand.
    Ask FixBot
  5. HP Sprocket 2-in-1 Flash Replacement: step 5, image 1 of 2 HP Sprocket 2-in-1 Flash Replacement: step 5, image 2 of 2
    • Remove four 2.5mm JIS #00 screws from the beige casing.
    Ask FixBot
  6. HP Sprocket 2-in-1 Flash Replacement: step 6, image 1 of 3 HP Sprocket 2-in-1 Flash Replacement: step 6, image 2 of 3 HP Sprocket 2-in-1 Flash Replacement: step 6, image 3 of 3
    • Use the iFixit opening tool to slowly work between the white and beige casing around the device.
    • Flip the device over and seperate the white casing from the rest of the device.
    • Be careful not to break the plastic while removing the case.
    • Gently remove the white casing as there is a ribbon cable connecting the two pieces.
    Ask FixBot
  7. HP Sprocket 2-in-1 Flash Replacement: step 7, image 1 of 1
    • Carefully remove the ribbon cable that connects the flash to the outer casing.
    Ask FixBot
  8. HP Sprocket 2-in-1 Flash Replacement, Flash: step 8, image 1 of 2 HP Sprocket 2-in-1 Flash Replacement, Flash: step 8, image 2 of 2
    • Using a Japanese Industrial Standard (J) screwdriver (J00 bit), remove three 2.5mm screws connecting the flash circuit board to the housing.
    Ask FixBot
  9. HP Sprocket 2-in-1 Flash Replacement: step 9, image 1 of 2 HP Sprocket 2-in-1 Flash Replacement: step 9, image 2 of 2
    • Carefully remove ribbon from the flash circuit board.
    • Remove flash circuit board from the housing.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 555
