Up to 20% off select tools
HP Split x2 Screen Replacement
Views: 14K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
119
All Time:
14,447
Comments: 6
1 comment on steps, 5 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Did you accidentally drop your device and shatter the screen? This guide will instruct you how to replace your broken screen. The first five steps tell you how to remove the rear cover of the case. The remaining six steps explain how to replace the screen.
    1. HP Split x2 Screen Replacement, Rear Cover: step 1, image 1 of 1
      • Opening the device voids the manufacturer warranty.
      • Power down the HP Split x2 before beginning the repair
      • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
      Ask FixBot
    2. HP Split x2 Screen Replacement: step 2, image 1 of 3 HP Split x2 Screen Replacement: step 2, image 2 of 3 HP Split x2 Screen Replacement: step 2, image 3 of 3
      • Remove the four white caps on the bottom edge of the tablet.
      • Use a tweezer to grasp white caps.
      • The white caps are easily lost. Store them in a secure place.
      Ask FixBot
    3. HP Split x2 Screen Replacement: step 3, image 1 of 1
      • Use a Phillips #000 screwdriver to remove the four 3mm screws.
      Ask FixBot
    4. HP Split x2 Screen Replacement: step 4, image 1 of 2 HP Split x2 Screen Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
      • Only the top and sides have tabs. Remove all tabs before lifting screen.
      Ask FixBot
    5. HP Split x2 Screen Replacement: step 5, image 1 of 2 HP Split x2 Screen Replacement: step 5, image 2 of 2
      • Separate the cover and the screen.
      • Gently lift the screen out of the cover.
      Ask FixBot
    1. HP Split x2 Screen Replacement, Screen: step 6, image 1 of 2 HP Split x2 Screen Replacement, Screen: step 6, image 2 of 2
      • Use a J0 screwdriver to remove the ten 4mm Phillips screws.
      Ask FixBot
    2. HP Split x2 Screen Replacement: step 7, image 1 of 2 HP Split x2 Screen Replacement: step 7, image 2 of 2
      • Peel back the large black tape.
      • Remove the 4mm Phillips screw.
      Ask FixBot
    3. HP Split x2 Screen Replacement: step 8, image 1 of 3 HP Split x2 Screen Replacement: step 8, image 2 of 3 HP Split x2 Screen Replacement: step 8, image 3 of 3
      • Remove three 2 mm zero insertion force (ZIF) connectors. Lift the black tab in front and then remove the ribbon from the rear.
      • Remove two larger zero insertion force (ZIF) connectors. Lift the black tab in front and then remove the ribbon from the rear.
      Ask FixBot
    4. HP Split x2 Screen Replacement: step 9, image 1 of 3 HP Split x2 Screen Replacement: step 9, image 2 of 3 HP Split x2 Screen Replacement: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • The last attachment to the screen is the bronze colored display cable connector.
      • Use a pair of tweezers to lift the metal bar and swing it to the other side on top of the cable.
      • Pull in the direction of the cable to remove the connector.
      Ask FixBot
    5. HP Split x2 Screen Replacement: step 10, image 1 of 1
      • Glue is holding the device together along the edges. The glue is can be very strong. A heat gun may be required to loosen the glue for removal of the digitizer to prevent damage to the screen.
      • Apply pressure to to the sides of the tablet.
      • Separate the digitizer from the the body of the tablet.
      Ask FixBot
    6. HP Split x2 Screen Replacement: step 11, image 1 of 2 HP Split x2 Screen Replacement: step 11, image 2 of 2
      • Glue is holding the screen on at the four corners.
      • Lift the screen up, breaking any adhesion forced by the glue.
      • Replace the old screen with a new one.
      Ask FixBot
11 other people completed this guide.
Author
with
Ricky Huitema
464 Reputation
2 Guides authored
Texas Tech, Team 22-5, Rauch Fall 2015 Member of Texas Tech, Team 22-5, Rauch Fall 2015
TTU-RAUCH-F15S22G5
3 Members
24 Guides authored
5 Guide Comments
This is not helpful because the one I am working on has no screws.
Matt Brown - Reply Share
I also have a Split x2 with no screws
dbmacaulay - Reply Share
I want change my screen because My screen is broken but I do not know , where I can buy my screen
Nohora Chitiva - Reply Share
ebay or amazon
Andrei Isari - Reply Share
Is HP Touch Screen Digitizer Glass for HP Split X2 The same as the screen being replaced here?? I need to know
Nwatu Chineme Edger - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 119
All Time: 14,447
