Up to 20% off select tools
HP Split x2 Rear Cover Replacement
Views: 4.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
88
All Time:
4,750
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Do you need access to the inner components of your device? This guide instructs you how to remove the rear cover of the case. After removing the cover, the interior components such as the display, RAM and wireless card can be accessed.
    1. HP Split x2 Rear Cover Replacement, Rear Cover: step 1, image 1 of 1
      • Opening the device voids the manufacturer warranty.
      • Power down the HP Split x2 before beginning the repair
      • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
      Ask FixBot
    2. HP Split x2 Rear Cover Replacement: step 2, image 1 of 3 HP Split x2 Rear Cover Replacement: step 2, image 2 of 3 HP Split x2 Rear Cover Replacement: step 2, image 3 of 3
      • Remove the four white caps on the bottom edge of the tablet.
      • Use a tweezer to grasp white caps.
      • The white caps are easily lost. Store them in a secure place.
      Ask FixBot
    3. HP Split x2 Rear Cover Replacement: step 3, image 1 of 1
      • Use a Phillips #000 screwdriver to remove the four 3mm screws.
      Ask FixBot
    4. HP Split x2 Rear Cover Replacement: step 4, image 1 of 2 HP Split x2 Rear Cover Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
      • Only the top and sides have tabs. Remove all tabs before lifting screen.
      Ask FixBot
    5. HP Split x2 Rear Cover Replacement: step 5, image 1 of 2 HP Split x2 Rear Cover Replacement: step 5, image 2 of 2
      • Separate the cover and the screen.
      • Gently lift the screen out of the cover.
      Ask FixBot
7 other people completed this guide.
Author
with
Ricky Huitema
464 Reputation
2 Guides authored
Texas Tech, Team 22-5, Rauch Fall 2015 Member of Texas Tech, Team 22-5, Rauch Fall 2015
TTU-RAUCH-F15S22G5
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 88
All Time: 4,750
