HP Split x2 13-g210dx Back Panel Replacement
    1. HP Split x2 13-g210dx Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
      • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
      • Remove the four 4-mm Phillips #0 screws.
      • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
      • You will hear popping noises as the clips separate from each other.
      Ask FixBot
1 Guide Comment
How do I put the felt cover back on?
Prince Phoenix - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 56
All Time: 810
