HP Spectre x360 15-bl012dx Display Assembly
    1. HP Spectre x360 15-bl012dx Display Assembly, Battery Replacement: step 1, image 1 of 2 HP Spectre x360 15-bl012dx Display Assembly, Battery Replacement: step 1, image 2 of 2
      • Power off the device before beginning disassembly.
      • Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
      • Next, remove the four visible Torx T5 3 mm on the sides.
      • Keep track of all screws.
      Ask FixBot
    2. HP Spectre x360 15-bl012dx Display Assembly: step 2, image 1 of 3 HP Spectre x360 15-bl012dx Display Assembly: step 2, image 2 of 3 HP Spectre x360 15-bl012dx Display Assembly: step 2, image 3 of 3
      • Please note the upper two feet are already removed. The device was given to us this way.
      • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
      • Remove the two 8 mm Phillips #1 screws under the feet.
      • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
      Ask FixBot
    3. HP Spectre x360 15-bl012dx Display Assembly: step 3, image 1 of 1
      • Use a spudger to pry the back panel off of the laptop. Work your way around the perimeter of the device to loosen the connection.
      • Take the back panel off of the laptop.
      Ask FixBot
    4. HP Spectre x360 15-bl012dx Display Assembly: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to remove six 4 mm screws securing the battery.
      Ask FixBot
    5. HP Spectre x360 15-bl012dx Display Assembly: step 5, image 1 of 3 HP Spectre x360 15-bl012dx Display Assembly: step 5, image 2 of 3 HP Spectre x360 15-bl012dx Display Assembly: step 5, image 3 of 3
      • Unplug the battery connector located on the motherboard.
      • Remove the battery from the laptop.
      Ask FixBot
    1. HP Spectre x360 15-bl012dx Display Assembly, Solid State Drive (SSD): step 6, image 1 of 3 HP Spectre x360 15-bl012dx Display Assembly, Solid State Drive (SSD): step 6, image 2 of 3 HP Spectre x360 15-bl012dx Display Assembly, Solid State Drive (SSD): step 6, image 3 of 3
      • Using minimal force, lift the locking bars on the USB board ZIF connector using a plastic opening tool or fingernail and pull out the ribbon cable.
      Ask FixBot
    2. HP Spectre x360 15-bl012dx Display Assembly: step 7, image 1 of 1
      • Using your fingers, remove the USB ribbon cable from the motherboard above the fan.
      Ask FixBot
    3. HP Spectre x360 15-bl012dx Display Assembly: step 8, image 1 of 2 HP Spectre x360 15-bl012dx Display Assembly: step 8, image 2 of 2
      • Remove the 3 mm Phillips #1 screw that secures the solid state drive to the board.
      • Please note this laptop was not supplied with an SSD, so this is not the same SSD you will find in your device.
      Ask FixBot
    4. HP Spectre x360 15-bl012dx Display Assembly: step 9, image 1 of 1
      • Slide the SSD card out of the connection at a 45 degree angle so that the SSD teeth are not bent.
      Ask FixBot
    1. HP Spectre x360 15-bl012dx Display Assembly, Motherboard: step 10, image 1 of 2 HP Spectre x360 15-bl012dx Display Assembly, Motherboard: step 10, image 2 of 2
      • Use a Phillips #1 screwdriver to remove two 3 mm screws from each fan.
      Ask FixBot
    2. HP Spectre x360 15-bl012dx Display Assembly: step 11, image 1 of 2 HP Spectre x360 15-bl012dx Display Assembly: step 11, image 2 of 2
      • Remove the six 2.5 mm Phillips #1 screws holding the heat sink in.
      Ask FixBot
    3. HP Spectre x360 15-bl012dx Display Assembly: step 12, image 1 of 2 HP Spectre x360 15-bl012dx Display Assembly: step 12, image 2 of 2
      • Pop up the eight tabs on all the ZIF connectors on the motherboard. This can either be done with a spudger or your finger nail.
      • Looking at the back of the laptop, there are two ZIF connectors in the top right (one should already be disconnected from the SSD removal), one in the top left, and 5 on the bottom. Indicated by red squares.
      Ask FixBot
    4. HP Spectre x360 15-bl012dx Display Assembly: step 13, image 1 of 3 HP Spectre x360 15-bl012dx Display Assembly: step 13, image 2 of 3 HP Spectre x360 15-bl012dx Display Assembly: step 13, image 3 of 3
      • Remove the five remaining connectors from the motherboard. Two on the bottom left, one on the bottom right, and one on the top right. These connectors pull up off the motherboard with no clips.
      Ask FixBot
    5. HP Spectre x360 15-bl012dx Display Assembly: step 14, image 1 of 2 HP Spectre x360 15-bl012dx Display Assembly: step 14, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the 2 mm screw from the Wi-Fi card that secures it to the motherboard.
      • Slide the Wi-Fi card out of the slot.
      Ask FixBot
    6. HP Spectre x360 15-bl012dx Display Assembly: step 15, image 1 of 3 HP Spectre x360 15-bl012dx Display Assembly: step 15, image 2 of 3 HP Spectre x360 15-bl012dx Display Assembly: step 15, image 3 of 3
      • Snake the speaker wires out of the plastic routings on the fans that hold the wires in place.
      • Lift the fans and heat sink out.
      • Remove the black heat shield under the heat sink.
      Ask FixBot
    7. HP Spectre x360 15-bl012dx Display Assembly: step 16, image 1 of 3 HP Spectre x360 15-bl012dx Display Assembly: step 16, image 2 of 3 HP Spectre x360 15-bl012dx Display Assembly: step 16, image 3 of 3
      • Clean the old thermal paste off of the heat sink, cpu, and gpu using isopropyl alcohol and a paper towel. The higher the percentage of the alcohol, the better. I used 91%.
      • Remember to apply thermal paste before installing the new motherboard with fresh thermal paste! A pea sized amount is plenty.
      Ask FixBot
    8. HP Spectre x360 15-bl012dx Display Assembly: step 17, image 1 of 2 HP Spectre x360 15-bl012dx Display Assembly: step 17, image 2 of 2
      • Using a Phillips #1 screwdriver, remove four screws from the motherboard.
      • Two 3 mm screws
      • Two 2 mm screws
      Ask FixBot
    9. HP Spectre x360 15-bl012dx Display Assembly: step 18, image 1 of 1
      • Remove the motherboard. Pull up the right side first, then pull it out.
      Ask FixBot
    1. HP Spectre x360 15-bl012dx Display Assembly, Display Assembly and Camera: step 19, image 1 of 2 HP Spectre x360 15-bl012dx Display Assembly, Display Assembly and Camera: step 19, image 2 of 2
      • Open the laptop so the screen is facing you.
      • Using a Phillips #1 screwdriver, remove two 5 mm screws from each hinge.
      Ask FixBot
    2. HP Spectre x360 15-bl012dx Display Assembly: step 20, image 1 of 1
      • Remove the display assembly by pulling the hinges out of the body.
      • This should not require much effort so make sure not to pull too hard. The cables will come out with the display assembly.
      • The camera and screen are one piece and must be replaced together.
      Ask FixBot
Cade Caldwell
202 Reputation
2 Guides authored
Clemson, Team 1-1, Hunter Spring 2022 Member of Clemson, Team 1-1, Hunter Spring 2022
CLEM-HUNTER-S22S1G1
5 Members
55 Guides authored
1 Guide Comment
en mi caso tuve que usar una secadora de pelo para darle calor a las partes de cinta "doble pega" y aun asi, me di cuenta una vez desensamblada la pantalla que la pantalla touch y la de video venian tambien pegadas de la misma manera y esta segunda parte no se explica en este video.
Alvaro Velasco - Reply Share
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 58
All Time: 2,905
