HP Spectre x2 12-a002dx Back Camera Replacement
    1. HP Spectre x2 12-a002dx Back Camera Replacement, Screen: step 1, image 1 of 1
      • Make sure the device is powered off and the kick stand is retracted.
      • The HP Spectre should be placed on a flat surface with the keyboard detached.
      Ask FixBot
    2. HP Spectre x2 12-a002dx Back Camera Replacement: step 2, image 1 of 3 HP Spectre x2 12-a002dx Back Camera Replacement: step 2, image 2 of 3 HP Spectre x2 12-a002dx Back Camera Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • To remove the screen, there is an entire system of clips which need to be undone as well as 4 Phillips M1.5x2.7 screws.
      • The screws should be removed using a Phillips #000 screwdriver. There is a sticker where the laptop attaches to the keyboard.
      • Heat the sticker (if needed) and use fine point tweezers to grip the sticker and remove it.
      Ask FixBot
    3. HP Spectre x2 12-a002dx Back Camera Replacement: step 3, image 1 of 3 HP Spectre x2 12-a002dx Back Camera Replacement: step 3, image 2 of 3 HP Spectre x2 12-a002dx Back Camera Replacement: step 3, image 3 of 3
      • Use the plastic opening tools or insert a spudger to begin unclipping the system.
      • Pry the screen off once all the clips have been unclipped.
      • The screen may shatter if not already shattered (beware of flying glass).
      Ask FixBot
      • This screen will break. There is double tape underneath the frame, which is not listed in here.
      Ask FixBot
    4. HP Spectre x2 12-a002dx Back Camera Replacement: step 5, image 1 of 3 HP Spectre x2 12-a002dx Back Camera Replacement: step 5, image 2 of 3 HP Spectre x2 12-a002dx Back Camera Replacement: step 5, image 3 of 3
      • Remove the connecting cable of the screen and battery. Use a spudger to reveal the adhesive strip and carefully peel it off.
      • Insert a spudger to the other end and release the ZIF connectors. Detach the cable.
      • While a metal spudger is pictured, use a black nylon spudger instead because it is ESD safe.
      Ask FixBot
    1. HP Spectre x2 12-a002dx Back Camera Replacement, Back Camera: step 6, image 1 of 1
      • The HP Spectre X2 Has three Cameras: A front facing webcam( blue arrow), a rear Facing webcam (orange arrow), and a 3d camera (red box). The 3d camera is covered by tape that connects to the heat sink.
      Ask FixBot
    2. HP Spectre x2 12-a002dx Back Camera Replacement: step 7, image 1 of 1
      • Begin by removing the ribbon that connects the front facing webcam to the motherboard. You can use a black nylon spudger as pictured to do this.
      Ask FixBot
    3. HP Spectre x2 12-a002dx Back Camera Replacement: step 8, image 1 of 2 HP Spectre x2 12-a002dx Back Camera Replacement: step 8, image 2 of 2
      • The Front facing webcam is secured to the HP spectre by the laptop frame and adhesive on the ribbon cable connecting the camera to the motherboard.
      • To remove the camera, peel back the ribbon cable and then slide the camera down and out of the laptop frame,
      Ask FixBot
    4. HP Spectre x2 12-a002dx Back Camera Replacement: step 9, image 1 of 2 HP Spectre x2 12-a002dx Back Camera Replacement: step 9, image 2 of 2
      • The rear facing webcam is secured in the same manner as the front.
      • Remove the ribbon connecting the camera to the motherboard, and slide the camera down and out of the laptop frame.
      Ask FixBot
    5. HP Spectre x2 12-a002dx Back Camera Replacement: step 10, image 1 of 2 HP Spectre x2 12-a002dx Back Camera Replacement: step 10, image 2 of 2
      • Next to the webcam is the Led light.
      • To replace the LED camera light, disconnect the ribbon cable from the motherboard. The LED light should slide freely out of the assembly.
      • The black nylon spudger may be used here again.
      Ask FixBot
Talha Bin Amir
684 Reputation
5 Guides authored
USF Tampa, Team S10-G6, Thompson Fall 2017 Member of USF Tampa, Team S10-G6, Thompson Fall 2017
USFT-THOMPSON-F17S10G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 101
All Time: 1,173
