HP Spectre Pro X360 G1 Battery Replacement
    1. HP Spectre Pro X360 G1 Battery Replacement, Battery: step 1, image 1 of 1
      • Turn off and unplug the laptop.
      • Flip the laptop so that the backplate is exposed.
      Ask FixBot
    2. HP Spectre Pro X360 G1 Battery Replacement: step 2, image 1 of 1
      • Remove the eight screws with the T5 Torx screwdriver.
      Ask FixBot
    3. HP Spectre Pro X360 G1 Battery Replacement: step 3, image 1 of 1
      • Using the plastic opening tools carefully lift the backplate.
      Ask FixBot
    4. HP Spectre Pro X360 G1 Battery Replacement: step 4, image 1 of 1
      • Remove the 4 screws holding down the battery with the Phillips #1 screwdriver.
      Ask FixBot
    5. HP Spectre Pro X360 G1 Battery Replacement: step 5, image 1 of 2 HP Spectre Pro X360 G1 Battery Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the 3 wires connected to the battery.
      • Tweezers may be needed to disconnect the wires.
      Ask FixBot
    6. HP Spectre Pro X360 G1 Battery Replacement: step 6, image 1 of 1
      • Lift the battery off of the alignment pins on the top cover and remove it from the device.
      Ask FixBot
Alexis Garcia
183 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 65
All Time: 2,482
