Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Remove the top and bottom rubber pads (the middle one can stay on)
Remove the 5 screws in the locations shown
Many things are now accessible, including the battery, SSD, and Wi-Fi card
Detach all the accessible ribbon cables, and unscrew the 6 small and 4 really small screws holding the battery in place (locations shown)
The cables running along the left and right sides of the battery will need to be pulled out of the clips holding them in place
NOTE: The battery does not need to be removed to access the SSD or Wi-Fi card
There is a tab under the battery ribbon cable that helps in removing the battery. It is attached to a strip of adhesive under the battery.
Pull the tab up away from the laptop to lift the battery. You will have to pull pretty hard, but don't pull quickly. Slowly increase the force until the battery becomes easy to remove.
You can also lift the battery on the backside between the tab and the ribbon cable
Detach the rest of the ribbon cables from the motherboard
It may be easiest to detach both sides of the ribbon cable to the Wi-Fi card
Unscrew the three screws holding the motherboard in place, and lift up and toward you (the bottom of the picture) to pull it out
The touchpad is also accessible before or after removing the motherboard via three screws
