HP Spectre 13-4002dx Display Replacement
    1. HP Spectre 13-4002dx Display Replacement, Motherboard: step 1, image 1 of 3 HP Spectre 13-4002dx Display Replacement, Motherboard: step 1, image 2 of 3 HP Spectre 13-4002dx Display Replacement, Motherboard: step 1, image 3 of 3
      • Remove the black tape from the motherboard.
      • Remove five screws using the Phillips #00 screwdriver that holds the motherboard in place.
      • Disconnect five ribbon cables, three power cables, and two wifi antennas from the motherboard.
      • Gently lift the motherboard out of the computer. Be careful to not to disturb the CPU fan.
      • Do not bend the motherboard.
      Ask FixBot
    1. HP Spectre 13-4002dx Display Replacement, Display: step 2, image 1 of 1
      • Remove four screws connecting the screen to the laptop case with the Phillips #00 screwdriver.
      Ask FixBot
    2. HP Spectre 13-4002dx Display Replacement: step 3, image 1 of 2 HP Spectre 13-4002dx Display Replacement: step 3, image 2 of 2
      • Bring the laptop screen to a 270 degree angle from the base.
      • Pull the display towards you for the display to pop out of the base.
      • Gently remove the display to ensure that the cables do not get caught on the case.
      Ask FixBot
    3. HP Spectre 13-4002dx Display Replacement: step 4, image 1 of 2 HP Spectre 13-4002dx Display Replacement: step 4, image 2 of 2
      • Remove the rubber seal around display with the opening tool.
      • Pry the display off.
      • Be careful while removing the display as it could snap and cause damage and/or injury. Be careful to not cut any wiring between the screen and its casing.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 72
All Time: 879
