HP Spectre 13-4002dx Battery Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
69
All Time:
1,871
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The laptop needs to be turned off during this procedure. Disconnecting the battery while the laptop is powered on may hurt you or damage your laptop.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. HP Spectre 13-4002dx Battery Replacement, Bottom Case: step 1, image 1 of 2 HP Spectre 13-4002dx Battery Replacement, Bottom Case: step 1, image 2 of 2
      • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
      Ask FixBot
    2. HP Spectre 13-4002dx Battery Replacement: step 2, image 1 of 2 HP Spectre 13-4002dx Battery Replacement: step 2, image 2 of 2
      • Pry up one corner of the bottom case with a spudger.
      • Work the spudger around the edges, making your way towards the bottom of the laptop.
      • Remove the bottom case.
      Ask FixBot
    1. HP Spectre 13-4002dx Battery Replacement, Battery: step 3, image 1 of 3 HP Spectre 13-4002dx Battery Replacement, Battery: step 3, image 2 of 3 HP Spectre 13-4002dx Battery Replacement, Battery: step 3, image 3 of 3
      • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
      • Remove the six 4 mm screws using a Phillips #000 screwdriver.
      Ask FixBot
    2. HP Spectre 13-4002dx Battery Replacement: step 4, image 1 of 3 HP Spectre 13-4002dx Battery Replacement: step 4, image 2 of 3 HP Spectre 13-4002dx Battery Replacement: step 4, image 3 of 3
      • Do not disconnect the cable connector shown in the red box.
      • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
      • Move the cable clear of the battery.
      Ask FixBot
    3. HP Spectre 13-4002dx Battery Replacement: step 5, image 1 of 2 HP Spectre 13-4002dx Battery Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Do not disconnect the cable connector located in the red box.
      • Use tweezers to remove the speaker cable from the groove attached to the battery.
      • Push the cable to the side so it does not get in the way of the battery removal.
      Ask FixBot
    4. HP Spectre 13-4002dx Battery Replacement: step 6, image 1 of 3 HP Spectre 13-4002dx Battery Replacement: step 6, image 2 of 3 HP Spectre 13-4002dx Battery Replacement: step 6, image 3 of 3
      • Disconnect the battery cable connector by sliding it out of the socket.
      • Move the battery out of the way if you need more room to disconnect the power cable.
      Ask FixBot
    5. HP Spectre 13-4002dx Battery Replacement: step 7, image 1 of 1
      • Carefully remove the battery.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 69
All Time: 1,871
