HP Spectre 13-3010dx Battery Replacement
Views: 20K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
122
All Time:
19,851
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use the Back Case Removal Guide as a prerequisite to this guide. Make sure you are wearing the Anti-Static Wrist Strap to avoid damaging the electronics.
It is always a good idea to remove the battery before working on any other components, for the safety of you and your computer.
Tools
    1. HP Spectre 13-3010dx Battery Replacement, Removal of the Back Case: step 1, image 1 of 2 HP Spectre 13-3010dx Battery Replacement, Removal of the Back Case: step 1, image 2 of 2
      Tool used on this step:
      $7.95
      Buy
      • Put on Anti Static Wrist Strap.
      • It is always a good idea to ground yourself when working with electronics to prevent static buildup. You wear this strap to protect you and your device from accidental electrostatic discharge (ESD) damage during repairs.]
      • Flip Computer Upside down.
      • Unscrew the eight 3.3mm black screws on the back casing with the T4 Torx Screwdriver.
      Ask FixBot
    2. HP Spectre 13-3010dx Battery Replacement: step 2, image 1 of 2 HP Spectre 13-3010dx Battery Replacement: step 2, image 2 of 2
      • Use the plastic opening tool to lift the back case off.
      • Use the plastic opening tools first; metal spudgers can damage your device.
      Ask FixBot
    1. HP Spectre 13-3010dx Battery Replacement, Battery: step 3, image 1 of 1
      • Remove the six 2.0mm silver screws and the two 3.2 mm black screws using the PH00 Phillips Screw Head.
      Ask FixBot
    2. HP Spectre 13-3010dx Battery Replacement: step 4, image 1 of 1
      • Gently unplug from CONO851 plug, using the plastic opening tool.
      Ask FixBot
    3. HP Spectre 13-3010dx Battery Replacement: step 5, image 1 of 2 HP Spectre 13-3010dx Battery Replacement: step 5, image 2 of 2
      • Gently lift up the battery and remove using the plastic opening tools.
      Ask FixBot
12 other people completed this guide.
4 Guide Comments
Good Job presenting the steps. I need to find a battery for my hp 13-3010dx ultrabook. Any ideas where one can be purchased.
Dawson Wilke - Reply Share
Hi Dawson Wilke, the battery seems has two kinds of interface, I suggest you take out your old battery check the battery model and product parameter, such as voltage and current as well as the interface, then search the right battery from online store. If you confuse on it, I am here willing to help you.
julie - Reply Share
Hi i did this found a battery online and did an installation of the replacement. Unfortunately it is not an original hp battery as none are available. However the issue I am having is that the new battery is not being detected. Any recommendations?
Leah Cleghorn - Reply Share
Cosmas Dorah - Reply Share
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 122
All Time: 19,851
