Up to 20% off select tools
HP Slate 8 Pro Microphone Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
20
Past 30 Days:
93
All Time:
986
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Introduction
Go to step 1 ↓
This guide should be able to help you replace the microphone if not working properly on your HP device. By following these steps you should have it replaced or fixed in not time.
    1. HP Slate 8 Pro Microphone Replacement, Remove the back cover: step 1, image 1 of 1
      • Before opening your device, turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down through the operating system.
      • Unplug your tablet from any power supply
      • Remove all external devices.
      • Remove back cover with plastic tools to avoid scratching the screen.
      Ask FixBot
    2. HP Slate 8 Pro Microphone Replacement, Remove screws: step 2, image 1 of 1
      • Remove all screws from the sides of the battery
      Ask FixBot
    3. HP Slate 8 Pro Microphone Replacement, Disconnect the battery cable: step 3, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Use a little bit of pressure to remove the cable.
      Ask FixBot
    4. HP Slate 8 Pro Microphone Replacement, Remove ZIF connector: step 4, image 1 of 1
      • Release the ZIF connector to which the microphone cable is attached
      Ask FixBot
    5. HP Slate 8 Pro Microphone Replacement, Remove the  microphone: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Remove microphone from panel using tweezers
      • Add your new microphone
      Ask FixBot
Author
with
Claudia
258 Reputation
2 Guides authored
USF Tampa, Team 9-4, Blackwell Fall 2014 Member of USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 20
Past 30 Days: 93
All Time: 986
