HP Slate 8 Pro IO Board Replacement
    1. HP Slate 8 Pro IO Board Replacement, Remove back cover: step 1, image 1 of 1
      • Turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down
      • Remove the back cover.
      Ask FixBot
    2. HP Slate 8 Pro IO Board Replacement, Disconnect battery cable: step 2, image 1 of 1
      • Disconnect the battery cable from the system board
      Ask FixBot
    3. HP Slate 8 Pro IO Board Replacement, Remove ribbon cables: step 3, image 1 of 1
      • Pull the yellow ribbons
      Ask FixBot
    4. HP Slate 8 Pro IO Board Replacement, Disconnect speaker cables: step 4, image 1 of 1
      • Disconnect the speaker cables from the I/O board
      Ask FixBot
    5. HP Slate 8 Pro IO Board Replacement, Remove screws: step 5, image 1 of 1
      • Remove the two Phillips PM1.5×4.0 screws that secure the I/O board to the display panel assembly.
      Ask FixBot
    6. HP Slate 8 Pro IO Board Replacement, Remove the IO board: step 6, image 1 of 1
      • Remove the IO board carefully.
      Ask FixBot
Claudia
258 Reputation
2 Guides authored
USF Tampa, Team 9-4, Blackwell Fall 2014 Member of USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,085
