HP Slate 8 Pro Front Facing Camera Replacement
    1. HP Slate 8 Pro Front Facing Camera Replacement, Front Facing Camera: step 1, image 1 of 2 HP Slate 8 Pro Front Facing Camera Replacement, Front Facing Camera: step 1, image 2 of 2
      • Secure the suction cup to the center of the screen.
      • Using a plastic opening tool, pry along the edges of the display while pulling upwards with the suction cup.
      Ask FixBot
    2. HP Slate 8 Pro Front Facing Camera Replacement: step 2, image 1 of 1
      • Use the Spudger to disconnect the ribbon cable to the upper camera by prying the connector away from the board.
      Ask FixBot
    3. HP Slate 8 Pro Front Facing Camera Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Use ESD safe tweezers to pry the camera away from the motherboard starting at the side opposite the ribbon cable.
      Ask FixBot
Andrew Hall
322 Reputation
3 Guides authored
IUPUI, Team 1-4, Renguette SU 2016 Member of IUPUI, Team 1-4, Renguette SU 2016
IUPUI-RENGUETTE-SU16S1G4
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 505
