Introduction
After many times of attempting to recharge the battery with no success, it may be time for your Slate's battery to be replaced. This repair guide is the primary step for all future repairs on your HP Slate, and is a basic process to master. In this guide, you will be removing the following:
- Back Cover
- Battery
Prepare your required tools, a new battery for your tablet, and set aside about 10 to 15 minutes to delve into the inner workings of your HP Slate.
Begin your replacement by using a T3 or T4 Torx screwdriver.
Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
18 other people completed this guide.
4 Guide Comments
Buenas tardes, como están? Consulta, la batería se puede reemplazar por otra genérica, existe algún repuesto?
Thanx for this amazing demo steps. Sir i need battery of this tab, coz i cant find this battery anywhere then someone told me to go online purchase it wil you so i decided to go online n finally i found ur page so plz arrange me the battery of this tab. My HP Slate 7 battery is not charging . I m from pakistan n my email is aasifbrothers79@gmail.com. Sir i m looking forward for ur kind reply .Thanx
Regards, Asif Sultan
where do i buy the battery in india… there is a site Maxbhi, I ordered the battery, they never send the battery neither returned the money…
I tried to plug the wrong cable into my HP Prime and have apparently damaged the connection in the calculator. Is there a procedure to repair that connection?
Stuart
