HP Probook 4540s BIOS Chip Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
9
Past 7 Days:
48
Past 30 Days:
225
All Time:
4,390
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 50 minutes - 2 hours
Difficulty: Difficult
Introduction
Go to step 1 ↓
If your HP Probook 4540s laptop has a locked BIOS and you are unable to install an Operating System because you can't access the BIOS settings, then a BIOS chip replacement will solve your problem.
The BIOS (Basic Input Output System) chip contains a program that is used to start the computer. In order to install an Operating System onto the computer, accessing the BIOS settings may be necessary in order for the computer to prioritize the CD or the USB flash drive to boot up before other types of data.
Before using this guide, try other solutions in order to unlock the BIOS chip such as contacting the original owner of the laptop and asking for the password. If you are the original owner, the product manufacturer (in this case, HP) is able to remove a BIOS admin password. Only after exhausting all possibilities do, we recommend desoldering the BIOS chip from the system board.
Steps 1-22 will walk you through how to disassemble the laptop in order to perform the replacement.
Step 19 will require you to remove the system board and the following steps will guide you on how to desolder the old BIOS chip and solder the new BIOS chip onto the system board.
If you have never soldered, we recommend you read the guide How To Solder and Desolder Connections to learn different techniques. We specifically recommend steps 11-14, as the BIOS chip is a surface-mounted connection on the system board.
Good luck!
Parts
Tools
    1. HP Probook 4540s BIOS Chip Replacement, BIOS Chip: step 1, image 1 of 1
      • Power off your device and unplug the power cord.
      • Place the laptop with the back case facing up.
      • Remove the external battery by sliding the latches towards each other.
      • Tilt the battery upwards and remove it from its socket.
      • Image Source: HP ProBook 4540s Battery Replacement
      Ask FixBot
    2. HP Probook 4540s BIOS Chip Replacement: step 2, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 2, image 2 of 2
      • Rotate the computer 180 degrees.
      • Slide the release latches towards each other.
      • Lift the bottom door away from the direction of the battery socket.
      Ask FixBot
    3. HP Probook 4540s BIOS Chip Replacement: step 3, image 1 of 3 HP Probook 4540s BIOS Chip Replacement: step 3, image 2 of 3 HP Probook 4540s BIOS Chip Replacement: step 3, image 3 of 3
      • Remove the four 4.0 mm Phillips PM2.0×4.0 screws that secure the hard drive to the computer.
      • Slide the hard drive to the left and lift it away from the computer.
      Ask FixBot
    4. HP Probook 4540s BIOS Chip Replacement: step 4, image 1 of 3 HP Probook 4540s BIOS Chip Replacement: step 4, image 2 of 3 HP Probook 4540s BIOS Chip Replacement: step 4, image 3 of 3
      • Remove the 6.0 mm Phillips PM2.5×6.0 screw that secures the optical drive.
      • Using a spudger, push the optical drive tab to the left.
      • With your other hand gently pull the optical drive to the left.
      Ask FixBot
    5. HP Probook 4540s BIOS Chip Replacement: step 5, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 5, image 2 of 2
      • Use the spudger to remove four rubber screw covers from the corners of the laptop.
      • Remove four 6.0 mm Torx T8 M2.5×6.0 screws from the corners of the computer.
      • Remove two 2.5 mm Phillips PM2.0×2.5 screws from the optical drive bay.
      Ask FixBot
    6. HP Probook 4540s BIOS Chip Replacement: step 6, image 1 of 1
      • Remove three 2.0 mm Phillips PM2.0×2.0 screws from the battery bay.
      • Remove one 3.0 mm Phillips PM2.0x3.0 security screw from the battery bay.
      Ask FixBot
    7. HP Probook 4540s BIOS Chip Replacement: step 7, image 1 of 1
      • Remove two 6.0 mm Phillips PM2.5×6.0 screws that secure the keyboard to the computer.
      Ask FixBot
    8. HP Probook 4540s BIOS Chip Replacement: step 8, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 8, image 2 of 2
      • Remove three 6.0 mm Phillips PM2.5×6.0 screws that secure the heat shield to the computer.
      • Slightly slide the heat shield to the left and lift it away from the computer.
      • The centermost screw on the heat shield is the final screw securing the keyboard in place.
      Ask FixBot
    9. HP Probook 4540s BIOS Chip Replacement: step 9, image 1 of 1
      • Remove seven 6.0 mm Torx T8 M2.5×6.0 screws that secure the top cover to the computer.
      Ask FixBot
    10. HP Probook 4540s BIOS Chip Replacement: step 10, image 1 of 3 HP Probook 4540s BIOS Chip Replacement: step 10, image 2 of 3 HP Probook 4540s BIOS Chip Replacement: step 10, image 3 of 3
      • Disconnect the fan cable from the system board.
      • Remove one 5.0 mm Phillips PM2.5×5.0 screw that secures the fan to the system board.
      • Lift the fan and remove it at an angle.
      Ask FixBot
    11. HP Probook 4540s BIOS Chip Replacement: step 11, image 1 of 3 HP Probook 4540s BIOS Chip Replacement: step 11, image 2 of 3 HP Probook 4540s BIOS Chip Replacement: step 11, image 3 of 3
      • Disconnect the 2 WLAN coaxial antenna cables from the terminals on the WLAN module by carefully prying up the connectors using your spudger or your hands
      • Remove the two 3.0 mm Phillips PM2.0×3.0 screws that secure the WLAN module.
      • Remove the WLAN module by pulling away to the right.
      Ask FixBot
    12. HP Probook 4540s BIOS Chip Replacement: step 12, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 12, image 2 of 2
      • The keyboard has a cable connected to the system board. Before lifting the keyboard completely off the laptop, disconnect the ribbon cable. We show this process in the next step.
      • Place the computer right-side up.
      • Place your hands over the keyboard, gently press down, and slide the keyboard towards yourself.
      • Gently pry the keyboard from the top.
      • Lift at an angle and only detach enough so you do not inadvertently detach the keyboard cable.
      Ask FixBot
    13. HP Probook 4540s BIOS Chip Replacement: step 13, image 1 of 3 HP Probook 4540s BIOS Chip Replacement: step 13, image 2 of 3 HP Probook 4540s BIOS Chip Replacement: step 13, image 3 of 3
      • Rotate the keyboard until it rests on the palm rest.
      • Disconnect the keyboard cable by lifting the keyboard connector latch and then disconnecting the keyboard cable from the system board.
      Ask FixBot
    14. HP Probook 4540s BIOS Chip Replacement: step 14, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 14, image 2 of 2
      • Disconnect the power button board cable by lifting the connector latch.
      • Using the blue tab, disconnect the cable from the system board.
      Ask FixBot
    15. HP Probook 4540s BIOS Chip Replacement: step 15, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 15, image 2 of 2
      • Disconnect the fingerprint reader board cable by lifting the keyboard connector latch.
      Ask FixBot
    16. HP Probook 4540s BIOS Chip Replacement: step 16, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 16, image 2 of 2
      • Use your thumbs to push and disconnect the speaker cable from the system board.
      Ask FixBot
    17. HP Probook 4540s BIOS Chip Replacement: step 17, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 17, image 2 of 2
      • Remove the two 6.0 mm Torx T8 M2.5×6.0 screws that secure the top cover to the computer.
      Ask FixBot
    18. HP Probook 4540s BIOS Chip Replacement: step 18, image 1 of 3 HP Probook 4540s BIOS Chip Replacement: step 18, image 2 of 3 HP Probook 4540s BIOS Chip Replacement: step 18, image 3 of 3
      • Using the spudger, pry between the top cover and bottom cover of the computer.
      • Be sure not to open it up fully because the touchpad cable is connected to the system board.
      • Remove the touchpad cable by lifting the latch and pulling on the blue tab.
      Ask FixBot
    19. HP Probook 4540s BIOS Chip Replacement: step 19, image 1 of 1
      • Remove four 4.5 mm Phillips PM2.5×4.5 screws that secure the system board to the computer.
      Ask FixBot
    20. HP Probook 4540s BIOS Chip Replacement: step 20, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 20, image 2 of 2
      • Unplug the USB connector cable by pinching the edge of the connector and pulling it away from the system board.
      Ask FixBot
    21. HP Probook 4540s BIOS Chip Replacement: step 21, image 1 of 3 HP Probook 4540s BIOS Chip Replacement: step 21, image 2 of 3 HP Probook 4540s BIOS Chip Replacement: step 21, image 3 of 3
      • Disconnect the display cable by pinching the attached black tab and pulling it straight up.
      • Disconnect the power cable by pinching the cable firmly and pulling away from the connector.
      • Disconnect the battery connector cable by pinching the cable firmly and pulling away from the connector.
      • The system board can be removed from the back cover of the computer to access the power and battery connector cables more easily. (refer to the third picture)
      Ask FixBot
    22. HP Probook 4540s BIOS Chip Replacement: step 22, image 1 of 3 HP Probook 4540s BIOS Chip Replacement: step 22, image 2 of 3 HP Probook 4540s BIOS Chip Replacement: step 22, image 3 of 3
      • Once the system board is no longer attached to the computer, place it on a flat surface as shown in the picture.
      • Flip the system board over.
      • The BIOS chip is located at the bottom of the system board near the RTC battery.
      • Optional Step: The optical drive extension board and the hard drive extension board can be removed from the system board.
      Ask FixBot
    23. HP Probook 4540s BIOS Chip Replacement: step 23, image 1 of 3 HP Probook 4540s BIOS Chip Replacement: step 23, image 2 of 3 HP Probook 4540s BIOS Chip Replacement: step 23, image 3 of 3
      • Unplug the Real-time clock (RTC) CMOS battery by gently pulling the battery cable away from the connector.
      • Grab the battery and gently pull it away from the system board.
      Ask FixBot
    24. HP Probook 4540s BIOS Chip Replacement: step 24, image 1 of 1
      Tool used on this step:
      Buy
      • Target the connectors of the BIOS chip with a heat gun.
      • Handle the heat gun with care. The heat gun will be at 344 degrees Celsius or 650 degrees Fahrenheit.
      • Circle the BIOS chip slowly so each connector heats up simultaneously. Heating one spot for too long can damage the system board.
      • Use the rubber handle tweezers, to prevent the BIOS chip from being blown off the system board.
      • This step will take some time. Be patient. You may apply flux on the connectors to help melt the solder.
      Ask FixBot
    25. HP Probook 4540s BIOS Chip Replacement: step 25, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 25, image 2 of 2
      • Gently pull the BIOS chip out using the rubber handle tweezers.
      • If the BIOS chip won't detach, apply more heat. Do not forcefully remove the BIOS chip as that could damage the connection pads.
      Ask FixBot
    26. HP Probook 4540s BIOS Chip Replacement: step 26, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 26, image 2 of 2
      • You may clean the area using small amounts of Isopropyl alcohol and using a Q-tip to clean the area.
      • Use your soldering iron to brush the pads.
      • If the pads came off when taking the BIOS chip out, you may apply small amounts of solder and brush the solder on the pads.
      Ask FixBot
    27. HP Probook 4540s BIOS Chip Replacement: step 27, image 1 of 2 HP Probook 4540s BIOS Chip Replacement: step 27, image 2 of 2
      • Place the new BIOS Chip and align the connectors with the pads.
      • Gently apply pressure to the BIOS chip downwards using the rubber handle tweezers while soldering the connectors with the pads to ensure that the connectors on the BIOS chip have good contact with the pads.
      • Do this until the BIOS chip is firmly in place
      • Check and ensure that the BIOS chip is firmly in place before reassembling the laptop.
      • All the connectors on the BIOS chip should be touching the pads.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order(starting from step 22).
2 other people completed this guide.
Attached Documents
Jacky Lim
391 Reputation
1 Guide authored
CSU Los Angeles, Team 12-2, Ribeiro Fall 2023 Member of CSU Los Angeles, Team 12-2, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S12G2
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 48
Past 30 Days: 225
All Time: 4,390
