HP ProOne 600 G1 Wi-Fi Adapter Replacement
  1. HP ProOne 600 G1 Wi-Fi Adapter Replacement, Back Removal: step 1, image 1 of 2 HP ProOne 600 G1 Wi-Fi Adapter Replacement, Back Removal: step 1, image 2 of 2
    • Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
    Ask FixBot
  2. HP ProOne 600 G1 Wi-Fi Adapter Replacement: step 2, image 1 of 2 HP ProOne 600 G1 Wi-Fi Adapter Replacement: step 2, image 2 of 2
    • Loosen the two 1/2" screws , with the T15 Torx Screwdriver, on each side of the stand. Remove stand.
    Ask FixBot
  3. HP ProOne 600 G1 Wi-Fi Adapter Replacement: step 3, image 1 of 1
    • Take out the single 3/8" screw, with the T15 Torx Screwdriver, from the middle of the backplate.
    Ask FixBot
  4. HP ProOne 600 G1 Wi-Fi Adapter Replacement: step 4, image 1 of 1
    • Remove the backplate by pulling it back towards you.
    • Small plastic tabs hold in the backplate, pull these up to remove it.
    Ask FixBot
  5. HP ProOne 600 G1 Wi-Fi Adapter Replacement, Wi-Fi Adapter: step 5, image 1 of 2 HP ProOne 600 G1 Wi-Fi Adapter Replacement, Wi-Fi Adapter: step 5, image 2 of 2
    • Locate the Wi-Fi adapter at the top right corner of where the stand once was.
    • Unscrew the screws using the Philips #1 Screwdriver.
    Ask FixBot
  6. HP ProOne 600 G1 Wi-Fi Adapter Replacement: step 6, image 1 of 1
    • Remove wire tabs from the left side of the Wi-Fi adapter.
    • Remove the adapter
    Ask FixBot
2 other people completed this guide.
Janelle Layman
258 Reputation
2 Guides authored
Cal Poly, Team 1-20, Maness Fall 2015 Member of Cal Poly, Team 1-20, Maness Fall 2015
CPSU-MANESS-F15S1G20
4 Members
12 Guides authored
1 Guide Comment
Muchas gracias, me ha sido de mucha ayuda , cambie la tarjeta por otra y funciono muy bien.
Eliseo - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 55
All Time: 5,022
