Up to 20% off select tools
HP ProOne 600 G1 RAM Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
29
Past 30 Days:
118
All Time:
3,420
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The RAM may be replaced or updated in order to increase your computer's speed and performance. Before performing any work, always remember to completely turn off and disconnect your computer from any power source.
    1. HP ProOne 600 G1 RAM Replacement, RAM: step 1, image 1 of 2 HP ProOne 600 G1 RAM Replacement, RAM: step 1, image 2 of 2
      • Push the unlock tabs on the back on the monitor in and towards each other while sliding the back cover up.
      Ask FixBot
    2. HP ProOne 600 G1 RAM Replacement: step 2, image 1 of 2 HP ProOne 600 G1 RAM Replacement: step 2, image 2 of 2
      • Locate the RAM in the bottom right hand corner.
      • Pull the two silver brackets holding the RAM away from each other.
      Ask FixBot
    3. HP ProOne 600 G1 RAM Replacement: step 3, image 1 of 1
      • Carefully remove RAM.
      Ask FixBot
4 other people completed this guide.
Author
with
Claire Crocker
273 Reputation
2 Guides authored
Cal Poly, Team 1-20, Maness Fall 2015 Member of Cal Poly, Team 1-20, Maness Fall 2015
CPSU-MANESS-F15S1G20
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 118
All Time: 3,420
