HP ProOne 600 G1 Fan Replacement
    1. HP ProOne 600 G1 Fan Replacement, Back Removal: step 1, image 1 of 2 HP ProOne 600 G1 Fan Replacement, Back Removal: step 1, image 2 of 2
      • Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
      Ask FixBot
    2. HP ProOne 600 G1 Fan Replacement: step 2, image 1 of 2 HP ProOne 600 G1 Fan Replacement: step 2, image 2 of 2
      • Loosen the two 1/2" screws , with the T15 Torx Screwdriver, on each side of the stand. Remove stand.
      Ask FixBot
    3. HP ProOne 600 G1 Fan Replacement: step 3, image 1 of 1
      • Take out the single 3/8" screw, with the T15 Torx Screwdriver, from the middle of the backplate.
      Ask FixBot
    4. HP ProOne 600 G1 Fan Replacement: step 4, image 1 of 1
      • Remove the backplate by pulling it back towards you.
      • Small plastic tabs hold in the backplate, pull these up to remove it.
      Ask FixBot
    1. HP ProOne 600 G1 Fan Replacement, Fan: step 5, image 1 of 3 HP ProOne 600 G1 Fan Replacement, Fan: step 5, image 2 of 3 HP ProOne 600 G1 Fan Replacement, Fan: step 5, image 3 of 3
      • Remove both 3/8" screws using the T15 Torx Screwdriver from the metal plate, and slide the plate to the left.
      Ask FixBot
    2. HP ProOne 600 G1 Fan Replacement: step 6, image 1 of 3 HP ProOne 600 G1 Fan Replacement: step 6, image 2 of 3 HP ProOne 600 G1 Fan Replacement: step 6, image 3 of 3
      • Unscrew three surrounding 1/4" screws, with the T15 Torx Screwdriver. Pull out the fan and attached wires.
      Ask FixBot
Victor Chacon
116 Reputation
1 Guide authored
Cal Poly, Team 1-20, Maness Fall 2015 Member of Cal Poly, Team 1-20, Maness Fall 2015
CPSU-MANESS-F15S1G20
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 44
All Time: 2,699
