HP ProBook x360 11 G5 EE Keyboard Assembly Replacement
    1. HP ProBook x360 11 G5 EE Keyboard Assembly Replacement, Keyboard Assembly: step 1, image 1 of 3 HP ProBook x360 11 G5 EE Keyboard Assembly Replacement, Keyboard Assembly: step 1, image 2 of 3 HP ProBook x360 11 G5 EE Keyboard Assembly Replacement, Keyboard Assembly: step 1, image 3 of 3
      • Remove the 4.1 mm screws with a T5 Torx screwdriver.
      • Remove the 4.1 mm screws using a JIS #0 screwdriver.
      Ask FixBot
    2. HP ProBook x360 11 G5 EE Keyboard Assembly Replacement: step 2, image 1 of 1
      • Use an opening pick to pry the corners of the keyboard deck.
      Ask FixBot
    3. HP ProBook x360 11 G5 EE Keyboard Assembly Replacement: step 3, image 1 of 3 HP ProBook x360 11 G5 EE Keyboard Assembly Replacement: step 3, image 2 of 3 HP ProBook x360 11 G5 EE Keyboard Assembly Replacement: step 3, image 3 of 3
      • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
      Ask FixBot
    4. HP ProBook x360 11 G5 EE Keyboard Assembly Replacement: step 4, image 1 of 3 HP ProBook x360 11 G5 EE Keyboard Assembly Replacement: step 4, image 2 of 3 HP ProBook x360 11 G5 EE Keyboard Assembly Replacement: step 4, image 3 of 3
      • Lift the keyboard assembly to expose two ribbon cables.
      • Lift the two plastic tabs that hold the cables in place on the motherboard
      • Slide the ribbon cables out of each connector.
      Ask FixBot
    5. HP ProBook x360 11 G5 EE Keyboard Assembly Replacement: step 5, image 1 of 2 HP ProBook x360 11 G5 EE Keyboard Assembly Replacement: step 5, image 2 of 2
      • Remove the keyboard assembly from the rest of the computer.
      Ask FixBot
3 other people completed this guide.
Kristen Gismondi
108,497 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
123 Members
79,996 Guides authored
1 Guide Comment
Merci pour ce tuto, je n'aurais pas su par quel bout le prendre ;)
Pour remplacer le clavier défectueux, il semble qu'il faille remplacer le top complet.
Lionel Faure - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 52
All Time: 2,268
