HP ProBook x360 11 G5 EE Display Panel Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
Past 7 Days:
25
Past 30 Days:
110
All Time:
4,433
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
In the guide, we will be covering how to replace the touchscreen display panel of an HP ProBook x360 11 G5 Education Edition. The display of a laptop is vital to a user since it allows them to perform the software functions they need.
Tools
    1. HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: step 1, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: step 1, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: step 1, image 3 of 3
      • Remove the 4.1 mm screws with a T5 Torx screwdriver.
      • Remove the 4.1 mm screws using a JIS #0 screwdriver.
      Ask FixBot
    2. HP ProBook x360 11 G5 EE Display Panel Replacement: step 2, image 1 of 1
      • Use an opening pick to pry the corners of the keyboard deck.
      Ask FixBot
    3. HP ProBook x360 11 G5 EE Display Panel Replacement: step 3, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 3, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 3, image 3 of 3
      • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
      Ask FixBot
    4. HP ProBook x360 11 G5 EE Display Panel Replacement: step 4, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 4, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 4, image 3 of 3
      • Lift the keyboard assembly to expose two ribbon cables.
      • Lift the two plastic tabs that hold the cables in place on the motherboard
      • Slide the ribbon cables out of each connector.
      Ask FixBot
    5. HP ProBook x360 11 G5 EE Display Panel Replacement: step 5, image 1 of 2 HP ProBook x360 11 G5 EE Display Panel Replacement: step 5, image 2 of 2
      • Remove the keyboard assembly from the rest of the computer.
      Ask FixBot
    1. HP ProBook x360 11 G5 EE Display Panel Replacement, Battery: step 6, image 1 of 2 HP ProBook x360 11 G5 EE Display Panel Replacement, Battery: step 6, image 2 of 2
      • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
      Ask FixBot
    2. HP ProBook x360 11 G5 EE Display Panel Replacement: step 7, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 7, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 7, image 3 of 3
      • Pry the battery up from the laptop using an opening pick.
      • Lift the battery out of its place.
      Ask FixBot
    1. HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: step 8, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: step 8, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: step 8, image 3 of 3
      • Use the opening pick and metal spudger to pry open the display cover.
      Ask FixBot
    2. HP ProBook x360 11 G5 EE Display Panel Replacement: step 9, image 1 of 2 HP ProBook x360 11 G5 EE Display Panel Replacement: step 9, image 2 of 2
      • Remove the ribbon wire that is attached to the display cover to fully detach it.
      Ask FixBot
    3. HP ProBook x360 11 G5 EE Display Panel Replacement: step 10, image 1 of 2 HP ProBook x360 11 G5 EE Display Panel Replacement: step 10, image 2 of 2
      • Remove the four 2.3 mm screws holding the screen in place with the JIS #0 screwdriver.
      Ask FixBot
    4. HP ProBook x360 11 G5 EE Display Panel Replacement: step 11, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 11, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 11, image 3 of 3
      • Lift the screen to disconnect the wire attaching it to the laptop.
      • Remove the display panel from the rest of the laptop.
      Ask FixBot
2 other people completed this guide.
Michelle Pina
506 Reputation
4 Guides authored
Gateway, Team 1-4, Pee Fall 2021 Member of Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 110
All Time: 4,433
