HP ProBook 650 G4 Keyboard Replacement
    1. HP ProBook 650 G4 Keyboard Replacement, Remove Back Plate: step 1, image 1 of 1
      • Loosen the 8 Philips screws circled in red in the photo. These screws are captive and should not come out fully.
      • Use pry tool starting at one of the hinges to release the clips all around the back plate
      • Remove plate and set aside.
      Ask FixBot
    2. HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: step 2, image 1 of 3 HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: step 2, image 2 of 3 HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: step 2, image 3 of 3
      • Unscrew the 3 Philips screws by the keyboard icons. (Circled in red)
      • The screws are captive and should not be removed fully.
      • Open the laptop screen
      • Use keyboard removal tool to push out the keyboard (circled in green)
      • anything that fits in the hole could be used if tool not available.
      Ask FixBot
    3. HP ProBook 650 G4 Keyboard Replacement, Releasing keyboard: step 3, image 1 of 2 HP ProBook 650 G4 Keyboard Replacement, Releasing keyboard: step 3, image 2 of 2
      • Work around the keyboard releasing the clips.
      • Clips are only located on the top, left, and right of the keyboard.
      • flip the keyboard towards the mouse pad taking care not to damage the ribbon cables.
      Ask FixBot
    4. HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: step 4, image 1 of 3 HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: step 4, image 2 of 3 HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: step 4, image 3 of 3
      • with a plastic spudger tool flip up the black clips to release the ribbon cables
      • Gently pull out the cables, there should be no resistance if the clips were opened properly.
      • There may be some adhesive connecting the cable to the keyboard (green arrow).
      Ask FixBot
    5. HP ProBook 650 G4 Keyboard Replacement, Install New Ribbon Cables: step 5, image 1 of 2 HP ProBook 650 G4 Keyboard Replacement, Install New Ribbon Cables: step 5, image 2 of 2
      • Gently fold the new ribbon cables at the 15B line
      • Gently push in the ribbon cables and press down the black clips.
      • Make sure that the cables are pushed in far enough. They have a line marking how far they should be inserted.
      • Slide in the bottom clips of the keyboard and flip towards the screen
      • Push the keyboard all around until all of the clips click into place.
      Ask FixBot
    6. HP ProBook 650 G4 Keyboard Replacement, Reassemble Laptop: step 6, image 1 of 2 HP ProBook 650 G4 Keyboard Replacement, Reassemble Laptop: step 6, image 2 of 2
      • Screw in the 3 keyboard screws
      • Push the back plate on and screw in the 8 screws
      • Go around the back plate making sure that it is clipped in all around.
      Ask FixBot
David Salerno
823 Reputation
4 Guides authored
1 Guide Comment
Datasheet motherboard
No power in d
evice
Mahmoud Ahmed - Reply Share
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 173
All Time: 4,840
