Up to 20% off select tools
HP ProBook 645 Keyboard Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
117
All Time:
5,383
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 25 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. HP ProBook 645 Keyboard Replacement, Remove 2 screws: step 1, image 1 of 1
      • Remove the two screws at the two indicated locations with the phillips head screw driver.
      Ask FixBot
    2. HP ProBook 645 Keyboard Replacement, Flip unit over and open lid.: step 2, image 1 of 1
      • Take a spudger tool and pry the keyboard down toward the mouse pad and up toward you. After you raise the keyboard there are tabs at the bottom. Pull the keyboard away from you, and it will dislodge.
      Ask FixBot
    3. HP ProBook 645 Keyboard Replacement, Ribbon Removal: step 3, image 1 of 1
      • 1. Remove ribbon by flipping the black tab up and gently pulling on the ribbon.
      • 2. This ribbon has no tab, gently pull on until it comes loose. To reinsert. Line it up carefully as not to damage the ribbon, and push gently.
      Ask FixBot
3 other people completed this guide.
Author
with
Doug
191 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 117
All Time: 5,383
