HP ProBook 640 G4 Trackpad Replacement
    1. HP ProBook 640 G4 Trackpad Replacement, Lower Case: step 1, image 1 of 2 HP ProBook 640 G4 Trackpad Replacement, Lower Case: step 1, image 2 of 2
      • Loosen the eight 2.5 mm-long Phillips captive screws securing the lower case.
      • Captive screws cannot be fully removed.
      Ask FixBot
    2. HP ProBook 640 G4 Trackpad Replacement: step 2, image 1 of 2 HP ProBook 640 G4 Trackpad Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the lower case and chassis, and twist it to create a gap.
      • Insert an opening tool into the gap.
      • Use the opening tool to pry around the entire perimeter of the device until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP ProBook 640 G4 Trackpad Replacement, Battery: step 3, image 1 of 3 HP ProBook 640 G4 Trackpad Replacement, Battery: step 3, image 2 of 3 HP ProBook 640 G4 Trackpad Replacement, Battery: step 3, image 3 of 3
      • Use a Phillips screwdriver to loosen the six 2.5 mm-long captive screws securing the battery.
      • Captive screws are not fully removable—they only loosen.
      • Slide and lift the battery out.
      Ask FixBot
    1. HP ProBook 640 G4 Trackpad Replacement, SSD: step 4, image 1 of 3 HP ProBook 640 G4 Trackpad Replacement, SSD: step 4, image 2 of 3 HP ProBook 640 G4 Trackpad Replacement, SSD: step 4, image 3 of 3
      • Loosen the four captive 2.5 mm-long Phillips screws securing the SSD.
      • Captive screws cannot be removed.
      • Grip the SSD and slide it out while lifting up.
      Ask FixBot
    1. HP ProBook 640 G4 Trackpad Replacement, RAM: step 5, image 1 of 3 HP ProBook 640 G4 Trackpad Replacement, RAM: step 5, image 2 of 3 HP ProBook 640 G4 Trackpad Replacement, RAM: step 5, image 3 of 3
      • Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
      • Repeat for the other RAM module.
      • Remove each of the two RAM modules.
      Ask FixBot
    1. HP ProBook 640 G4 Trackpad Replacement, Internal Casing: step 6, image 1 of 3 HP ProBook 640 G4 Trackpad Replacement, Internal Casing: step 6, image 2 of 3 HP ProBook 640 G4 Trackpad Replacement, Internal Casing: step 6, image 3 of 3
      • Remove 5 2.5 mm Phillips head screws.
      • Remove 12 6 mm Torx head screws.
      • Remove 2 2.5 mm Phillips head screws.
      • Loosen 4 2.5 mm Phillips head screws.
      • The 4 2.5 mm Phillips head screws do not come out; only loosen and are built into the frame.
      Ask FixBot
    1. HP ProBook 640 G4 Trackpad Replacement, Fan and Heat Sink: step 7, image 1 of 1
      • Loosen the four 2.5 mm-long Phillips screws securing the heat sink.
      • Loosen the four 2.5 mm-long Phillips screws securing the fan.
      Ask FixBot
    2. HP ProBook 640 G4 Trackpad Replacement: step 8, image 1 of 1
      • Lift the heat sink out.
      Ask FixBot
    3. HP ProBook 640 G4 Trackpad Replacement: step 9, image 1 of 3 HP ProBook 640 G4 Trackpad Replacement: step 9, image 2 of 3 HP ProBook 640 G4 Trackpad Replacement: step 9, image 3 of 3
      • Push the fan connector directly out of it socket.
      • Remove the fan.
      Ask FixBot
    1. HP ProBook 640 G4 Trackpad Replacement, Motherboard: step 10, image 1 of 3 HP ProBook 640 G4 Trackpad Replacement, Motherboard: step 10, image 2 of 3 HP ProBook 640 G4 Trackpad Replacement, Motherboard: step 10, image 3 of 3
      • Remove the 2 mm-long Phillips screw.
      • Remove the 2.5 mm-long Phillips screw.
      Ask FixBot
    2. HP ProBook 640 G4 Trackpad Replacement: step 11, image 1 of 3 HP ProBook 640 G4 Trackpad Replacement: step 11, image 2 of 3 HP ProBook 640 G4 Trackpad Replacement: step 11, image 3 of 3
      • Disconnect the ZIF connector by gently lifting the hinged locking flap on the connector's top edge until it's vertical, then carefully slide the ZIF connector straight out.
      • Lift the motherboard at an angle making sure to slide the ports out the casing.
      Ask FixBot
    1. HP ProBook 640 G4 Trackpad Replacement, Trackpad: step 12, image 1 of 2 HP ProBook 640 G4 Trackpad Replacement, Trackpad: step 12, image 2 of 2
      • Remove the nine 3.4 mm screws using a Phillips #000 screwdriver.
      • Lift and take out the trackpad.
      Ask FixBot
Adnan Shinwari
253 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 66
All Time: 175
