Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓Use this guide to replace a damaged or faulty speaker in your HP ProBook 640 G4 laptop.
The speaker is responsible for producing sound from your device. If you are experiencing issues such as no audio, distorted sound, low volume, or crackling noises, the speaker may need to be replaced.
Before starting, check your system volume settings and test your audio with headphones or external speakers to make sure the issue isn’t related to software or audio drivers.
Make sure to power off your laptop and disconnect it from any power source before beginning the repair.
Tools
Loosen the eight 2.5 mm-long Phillips captive screws securing the lower case.
Use a Phillips screwdriver to loosen the six 2.5 mm-long captive screws securing the battery.
Slide and lift the battery out.
Loosen the four captive 2.5 mm-long Phillips screws securing the SSD.
Grip the SSD and slide it out while lifting up.
Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Repeat for the other RAM module.
Remove each of the two RAM modules.
Remove 5 2.5 mm Phillips head screws.
Remove 12 6 mm Torx head screws.
Remove 2 2.5 mm Phillips head screws.
Loosen 4 2.5 mm Phillips head screws.
Loosen the four 2.5 mm-long Phillips screws securing the heat sink.
Loosen the four 2.5 mm-long Phillips screws securing the fan.
Remove the 2 mm-long Phillips screw.
Remove the 2.5 mm-long Phillips screw.
Loosen the one screw 3.4mm with a Phillips #000 screwdriver.
Take the speaker out.
