HP ProBook 640 G4 SSD Replacement
    1. HP ProBook 640 G4 SSD Replacement, Lower Case: step 1, image 1 of 2 HP ProBook 640 G4 SSD Replacement, Lower Case: step 1, image 2 of 2
      • Loosen the eight 2.5 mm-long Phillips captive screws securing the lower case.
      • Captive screws cannot be fully removed.
      Ask FixBot
    2. HP ProBook 640 G4 SSD Replacement: step 2, image 1 of 2 HP ProBook 640 G4 SSD Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the lower case and chassis, and twist it to create a gap.
      • Insert an opening tool into the gap.
      • Use the opening tool to pry around the entire perimeter of the device until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP ProBook 640 G4 SSD Replacement, Battery: step 3, image 1 of 3 HP ProBook 640 G4 SSD Replacement, Battery: step 3, image 2 of 3 HP ProBook 640 G4 SSD Replacement, Battery: step 3, image 3 of 3
      • Use a Phillips screwdriver to loosen the six 2.5 mm-long captive screws securing the battery.
      • Captive screws are not fully removable—they only loosen.
      • Slide and lift the battery out.
      Ask FixBot
    1. HP ProBook 640 G4 SSD Replacement, SSD: step 4, image 1 of 3 HP ProBook 640 G4 SSD Replacement, SSD: step 4, image 2 of 3 HP ProBook 640 G4 SSD Replacement, SSD: step 4, image 3 of 3
      • Loosen the four captive 2.5 mm-long Phillips screws securing the SSD.
      • Captive screws cannot be removed.
      • Grip the SSD and slide it out while lifting up.
      Ask FixBot
Isaiah Rose
169 Reputation
2 Guides authored
UMass Dartmouth, Team 1-5, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-5, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 79
All Time: 405
