Tools
Introduction
Go to step 1 ↓The HP Probook 640 G4 is a business class 14 inch laptop that is designed for durability. This guide will walk you through how to safely replace the RAM. A failing RAM can cause random freezes and "out of memory" errors.
Before you start be sure to power the laptop off completely, unplug the AC adapter, and remove all external devices. Work on a clean flat surface. Make sure you have all of the right tools and parts available.
If your Probook is slow with many browser tabs, shows "low memory" warnings, or crashes often, replacing the RAM often helps. After replacement, be sure to run Windows Memory Diagnostic to verify that your replacements are recognized.
Loosen the eight 2.5 mm-long Phillips captive screws securing the lower case.
Use a Phillips screwdriver to loosen the six 2.5 mm-long captive screws securing the battery.
Slide and lift the battery out.
Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Repeat for the other RAM module.
Remove each of the two RAM modules.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
