Introduction
The HP Probook 640 G4 is a business class 14 inch laptop that is designed for durability. This guide will walk you through how to safely replace the motherboard. A failing motherboard can cause no power conditions, dead ports, or random freezes.
Before you start be sure to power the laptop off completely, unplug the AC adapter, and remove all external devices. Work on a clean flat surface. Make sure you have all of the right tools and parts available.
If the laptop shows no signs of life, won't charge despite a battery replacement, or has visible board corrosion then a motherboard replacement is often the fix.
Loosen the eight 2.5 mm-long Phillips captive screws securing the lower case.
Use a Phillips screwdriver to loosen the six 2.5 mm-long captive screws securing the battery.
Slide and lift the battery out.
Loosen the four captive 2.5 mm-long Phillips screws securing the SSD.
Grip the SSD and slide it out while lifting up.
Two clips secure each RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Repeat for the other RAM module.
Remove each of the two RAM modules.
Remove 5 2.5 mm Phillips head screws.
Remove 12 6 mm Torx head screws.
Remove 2 2.5 mm Phillips head screws.
Loosen 4 2.5 mm Phillips head screws.
Loosen the four 2.5 mm-long Phillips screws securing the heat sink.
Loosen the four 2.5 mm-long Phillips screws securing the fan.
Remove the 2 mm-long Phillips screw.
Remove the 2.5 mm-long Phillips screw.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
