HP ProBook 640 G4 Display Assembly Replacement
    1. HP ProBook 640 G4 Display Assembly Replacement, Display Assembly: step 1, image 1 of 1
      • Insert an opening tool into the black thin cover on the outside to remove the display bezel.
      Ask FixBot
    2. HP ProBook 640 G4 Display Assembly Replacement: step 2, image 1 of 1
      • Lift the bezel and remove it to access the screen.
      Ask FixBot
    3. HP ProBook 640 G4 Display Assembly Replacement: step 3, image 1 of 2 HP ProBook 640 G4 Display Assembly Replacement: step 3, image 2 of 2
      • Remove the four 3.4 mm screws using a Phillips #000 screwdriver.
      • Lift and remove the display screen.
      Ask FixBot
    4. HP ProBook 640 G4 Display Assembly Replacement: step 4, image 1 of 2 HP ProBook 640 G4 Display Assembly Replacement: step 4, image 2 of 2
      • Unhook the display screen that is attached with a small hook.
      • Remove the display assembly.
      Ask FixBot
Adnan Shinwari
253 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 95
All Time: 236
