HP ProBook 640 G3 Lower Case Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
67
All Time:
218
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the lower case on a HP ProBook 640 G3.
Tools
    1. HP ProBook 640 G3 Lower Case Replacement, Lower Case: step 1, image 1 of 3 HP ProBook 640 G3 Lower Case Replacement, Lower Case: step 1, image 2 of 3 HP ProBook 640 G3 Lower Case Replacement, Lower Case: step 1, image 3 of 3
      • Before beginning, power the device down and disconnect all peripheries.
      • Remove the eight 6 mm-long Phillips screws securing the lower case.
      • Insert an opening pick into the seam between the lower case and chassis.
      • Slide the pick around the entire perimeter of the device until the lower case releases.
      • Remove the lower case.
      Ask FixBot
Connor Bassolino
26,159 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 67
All Time: 218
