HP ProBook 640 G2 Battery Replacement
    1. HP ProBook 640 G2 Battery Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop so the bottom is facing up.
      • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
      • Use a Torx T9 screwdriver to remove the single 6 mm screw.
      Ask FixBot
    2. HP ProBook 640 G2 Battery Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to carefully pry the bottom case.
      • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
      • Remove the bottom cover.
      Ask FixBot
    3. HP ProBook 640 G2 Battery Replacement: step 3, image 1 of 3 HP ProBook 640 G2 Battery Replacement: step 3, image 2 of 3 HP ProBook 640 G2 Battery Replacement: step 3, image 3 of 3
      • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
      • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
      Ask FixBot
Note - Be sure to dispose of your old battery responsibly! Check out iFixit's Guide on Recycling E-waste.
For optimal performance, calibrate your newly installed battery after completing this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 114
All Time: 591
